Question about RCA L46WD22 Television
I have a 42 inch rca tv model WB22YX5 componet inputs dont work
I have a 42 inch rca tv model WB22YX5 for some reason all the componet inputs dont work any more and the hdmi input dont work but good picture any one know whats wrong??
  • RCA Master
  • 12,061 Answers
Sometimes, these inputs get damaged by ESD, or stray voltages, and become damaged. You may just need to give the set a reset, unplug an leave for 5 mins or so, and try again, if still no go, see if there is anything, in the troubleshooting procedures, that can help. It may just be a board replacement, If you decide, to get it repaired, please first contact RCA head office, and ask for a referral, to an authorised service center.
http://www.scribd.com/doc/7581822/RCA-Chssis-CTC-175176177186187-TV-Training-Manual
Posted on May 05, 2010
RCA LCD TV (L42WD22yx6)
Look to see if those inputs in the on screen menu show or not---locked out maybe? Someone using just the other inputs may have disabled them.
Aug 29, 2012 | RCA L42WD22 42 in. LCD Television
I have a Samsung LCD TV model #LN46B301FUZA, a dish VIP622DVR a pioneer VSX-D307 reciever and a Pioneer DV-414 DVD player that I am trying to get hooked up. The Dish tech hooked up the TV and DVR using a...
I can't find your TV model to have a look at the manual. Normally you'd use a 3-plug RCA cable (Red, White, Yellow) to connect the audio and video outputs of the DVR to an RCA input on the TV. Then, hoping you have RCA OUTPUTS from the TV, you'd use a 2-plug RCA cable to take an Audio OUT from the TV into one of the receiver's Audio inputs (assuming you want to play TV sound through the receiver.
If you have no RCA inputs on the TV, you can get an RCA to HDMI Converter from Amazon for $10-$15 to convert the output of the DVD player from 3-plug RCA to HDMI, then put that into one of the HDMI inputs on the TV. Likewise, if you have only an OPTICAL audio output from the TV you can get a converter for that -- Optical audio to RCA stereo -- and put that into your receiver as an input.
Jan 20, 2018 | Pioneer Computers & Internet
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Componet input do not work. Error messages searching for signal,.. no input signal. It is not the source or the cables. Can wiggle the componet inputs on tv and get flash of pix or intermittant. Samsung...
the wiggling of the cables and actually getting a response usually means there is a lose connection/cold solder joint. Narrow the possible connections down and resolder the few solder points or take it to a repair shop.
Jul 21, 2010 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
How do I attach my dvd to the 42 inch tv to watch a movie? Do I just attached the RGB connections?
An HDMI cable is best however a set of Component cables will also work. The Component (RGB) will also carry a high def image. You will need five cables in all. The Red, Blue, Green for the video and two additional RCA cables for audio (red and white). Color match the inputs to both the DVD and the TV. Select "Video" source from the Input menu of the TV. Confirm this worked.
Jul 01, 2010 | Haier HL42R 42 in. LCD TV
MY TV is LG 42 PG 60D , serial number :803KCBD35285
Sound like ur Tuner board have intermitint problems,it work awhile,than the old problems occur again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Because this problems come and goes.
Apr 30, 2010 | LG 42LC2D 42 in. LCD HDTV
Toshiba regza all but the hdmi input on my 42 inch toshiba regza
In most cases the HDMI issues are the source itself. Try another item like a DVD player or BluRay player. If they work then its a compatibility issue. If they don't then the HDMI receiver board in the TV is bad. Please take a moment to rate my answer. Thanks...
Nov 20, 2009 | Toshiba 42HL167 42 in. LCD Television
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Where is the cable tv input to screw a normal cable cord into the back of my akai 42 inch plasma screen? Does it have one?
Every T.V. will have a Coaxial input on it. Just keep searching. More than likely if you have all your rca/componet inputs on the back of your t.v, it should be towards the bottom of those, and if not, Not to often, but it could be behind a hidden flap. Read your manual, it will let you know exactly where it is.
Sep 01, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Color bar
Sounds like the TV is defective, if I were you I would take it back. There probably isn't much you can do on your own to fix it.
Jan 08, 2009 | Televison & Video
RCA L46WD22 Television Logo
242 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
