Question about Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- N150X2-L01 (N150X2L01) CD-ROM Drive
Sound Problem I have no sound on my laptop because it does not recognize that there is an audio device how do i fix this problem
  • 807 Answers
You may have to go in to the bios and enable the audio device.
Posted on Mar 26, 2008
How do I get sound on Advent L75118 laptop?
That "no audio devices are installed" message does not refer to the headphones, but to the sound chip in the laptop. Your operating system is not seeing the laptop's audio chip, which is built into the laptop's motherboard. This could be due to a hardware failure, or a software problem (corruption of the audio chip's driver). To tell which of these is the problem, open "Device Manager" and look for any device that may be highlighted with an exclamation mark. If anything that resembles an audio device is so marked, it means the operating system is able to see the audio chip. and you problably don't have (total) audio hardware failure. You have to search, download and install the driver for this "problem" device. If no audio device is seen at all, then there is probably a hardware fault with the motherboard/audio chip. All is not lost. You can buy an inexpensive USB audio dongle that will allow you to route sound out from the laptop into external speakers or headphones. However, you'll lose the use of the internal laptop speakers that were dependent on the internal audio device (chip).
Nov 09, 2017 | Advent Computers & Internet
Laptop sound
To start, it may be a longshot, but try turning off bluetooth, in case that is interfering with the sound, or sending the sound elsewhere, like to a bluetooth speaker or cell phone. Also, try downloading the ESET NOD32 online virus scanner using Fireofox, to rule out any pesky viruses messing with your VAIO.
If problem persists....
Open the start menu, and check around for any VAIO support software that can check your system for errors and hopefully fix them.
Open the sound icon next to the date and time on the lower right portion of the screen, and open the mixer, where you are able to see the volume for mic, speaker, and a bunch of other things. Check to see that no mute has been selected, or that no audio has been disabled.
Look inside the control panel, and find sounds and audio. When you open it, click around and see it the wrong audio device got somehow selected, or if NO audio device is selected, and go ahead and select a different device from the drop down menu to see if picking another device fixed the issue.
Next look inside your device manager, and see if the audio device shows up, and hopefully it does, then see if it has a yellow exclamation point next to it. Even if it does not, click on it, and find the option to add or update the driver for it. You may have to insert the restore DVD that (hopefully) came with your VAIO.
The next options, in case nothing has worked, are to do a full reinstall of your Windows OS, drastic but we are at that point. Or else, I have seen instances where the actual sound card in the laptop has died, which would be one reason why Windows no longer recognizes any audio device as being there.
I hope one of these fixed the issue for ya!
Nov 08, 2013 | Sony VAIO VGN-T350P/T Notebook
The sound has just stopped working, i once had this happen before and i did google and could fix it its some fault in the computer but that was a while ago and i cant remember how to fix it
try going to sony's site and downloading the audio drivers for your laptop after uninstalling them via device manager. under xp right click on my computer go to device manager select audio device and delete it under win 7 go to my computer then system properties then device manager and do that. after that windows will re recognize the audio system and look for the drivers and either use the one windows gives you or from sony's website.
Mar 14, 2011 | Sony VAIO VGN-CR120E Notebook
No sound but Device managers says everything is working alright
Go ahead and download the audio driver from the Acer website and try to reinstall it. If that doesn't work, right click on the audio device in device manager and click uninstall. Reboot your laptop and Windows will recognize the sound card and reinstall the drivers. If it doesn't reinstall, just install them manually. If still no sound, it may be a hardware problem.
Regards,
Matt
Mar 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
XP laptop no longer recognizes any USB speakers, and internal speakers dont work. USB speakers do not appear in the audio controls. the only 'device' listed under Sound Playback is SoundMax Digital Audio,...
Nothing wrong with your USB ports. MagicJack has changed your audio and driver settings so it can use the sound system for phone calls. The changes exist whether the Jack device in plugged in or not.
You can confirm the problem by uninstalling MagicJack and reinstalling your sound drivers. Should fix the problem.
You'll probably need to contact the maker of the MagicJack device for a workaround. Might be something specific to your laptop/operating system.
Nov 13, 2009 | Toshiba Satellite M45-S2653 Notebook
SOUND DEVICE NOT FOUND WHILE INSTALLING OUDIO
hello , i would attempt to install/update any bios software for the computer so that it will recognize the sound device.
Oct 02, 2009 | Compaq Presario 700 470024-192 Notebook
Sound Device Missing?? I have an IBM Thinkpad X61s
You should open the Device Manager through the Control Panel and check if the audio device is recognized and has the proper driver installed.
If an unknown or other device is listed, that might mean you need to install the drivers again.
Aug 07, 2009 | Dell Inspiron 6400 Notebook
HI, I have an emu 1616m soundcard. My laptop recognizes the EMU and the pulgins, but no sound comes out of the monitors.Only from the laptop speakers.
You have to select the EMU as the default playback device in Windows and or select it as the playback device in the software you are using for recording or playback.
Go to Control Panel and Sound and Audio Devices icon, and select the Audio tab. There is a drop down box that lists all playback devices. You have to select the EMU in there.
That should get you working.
Dec 29, 2008 | E-Mu 1616M Sound Card
No audio device installed on my laptop
I'm not sure whether this is the exact same problem, as I was having, but mine just randomly quit while I was listening to music this morning. I got messages saying "No audio device installed", but when I went to device manager, all my audio devices said they were working properly. If this is the case with you, simply restart your computer. It may take a couple restarts, but this should work. My sound was back even before it finished shutting down.
If it helps anyone trying to get to the root of this problem, I am running XP on a Dell B130 laptop, with the following devices listed in Device Manager:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Hope this helps!
Jan 22, 2008 | Creative Labs Sound Blaster Audigy LS...
Wheres the sound?
Here's the audio driver: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=1043305&moid=1042107&rpn=PSM43U&BV_SessionID=@@@@0159702921.1188418701@@@@&BV_EngineID=cccdaddllgjjdegcgfkceghdgngdgmn.0&ct=DL&all_docs=false To fix your cd drive not recognized, do this: Choose Start > Run. Type regedit in the Open text box. Navigate to this registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Then delete it.
Aug 29, 2007 | Toshiba Satellite M45-S165 Notebook
Computers & Internet Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
