Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
Hi its AKSHAY I HAVE 4GB TRANSCEND PEN DRIVE AND I HAVE TRYED EVERYTHING BUT ITS STILL WRITE PROTECTED WHEN I TRY TO FORMAT IT
    Sergeant:
  • 420 Answers
Try using this software to format it.. www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
Posted on Sep 10, 2010
HI I HAVE TRANSCEND 4GB PEN DRIVE...I M TRYING TO OPEN MY PEN DRIVE OR TRYING TO FORMATTING BUT MY PEN DRIVE CONNECT 10SEC AND DISCONNECT....EVERY COMPUTER AND ANY LAPTOP I USE BUT SAME PROBLEM IS RUNNING...
Plug in the drive.
  • Right click on Computer, Properties
  • Select Manage
  • Select Disk Management
  • After the drive "disappears" if it is no longer visible in disk managment, I'd say it is a bad drive. If it shows as offline, try deleting any partitions on it and formatting it in disk managment.
Dec 18, 2012 | Electronics - Others
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Write protected
write protected i am not able to copy nor delete files from my 4gb transcend memory card
Apr 17, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
I have 4 gb transcend pen drive which shows write protection. How to remove write protection.
This is a bear of a problem with Transcend owners. You need to use their new Jet Flash format utility. So before doing so, copy everything off your drive to a folder in My Documents. This tool will then format your drive so you can start adding new, more organized data of your choice.
Then, try to remember to keep your data on the pen drive below the 4GB limit. This all has to do with binary math and base 10 math. The drive really doesn't hold 4GB of data, its way lower than that around 3.6GB. So, keep this in mind and keep this format tool around for future use.
I found this download link here, which is dynamic and not static but should work by clicking here.
Should that not work go to this referrer page here. You will have to start by select your product type and then go down through each selection list until you find your model and then the downloads for it will be listed. Click on the Jet Flash utility download eventually.
Personally, I think they could have done this much better and made this way simpler for consumers to find the formatting tool.
Let me know if you run into trouble and if you don't hear from me in 24 hours click on my user name and send me an Ask Me message, I'll get that message and I'll be glad to help you out.
Regards,
Worldvet
Jan 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How can i remove write protect from my 4 GB transcend pen drive
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel auto run operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Jan 16, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cant format my transcend 2 gb pen drive it says write protected
do you see any switches on the side of it ? if so move it to the other position and try again.
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can't format my 2 gb transcend pen drive it saya write protect
Some usb drives/flash drives have a little switch that locks it and makes it read only to avoid accidentally losing important files. Try looking for a small switch somewhere on the case of the drive and switch it to the other position if you find it.
Electronics - Others Logo
88 people viewed this question
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
