Cycle starts but then stops and code F35 flashes
  • r_gomes_mcga May 05, 2010
    Kenmore Elite Smartwash Quiet Pak He5 110.47781700
    Thank you!!! You've been very helpful. Rosemary
  • 3,230 Answers
Well first of all you can check out the Lid switch - If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Please tell us the brand and the model number of your washing machine so we can help you in details......
Good Luck!!
Thanks
Posted on May 05, 2010
  • Mukesh Kumar May 05, 2010
    The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. Analog pressure switch is an expensive part. Remove the top lid by undoing the three fasteners on the back of the top lid. Pull the lid towards the back and lift up.  The pressure switch is a brown module inside a black housing with a black rubber tube connected to it. It is locate on the top right panel towards the rear of the washer. Rotated it 90 degrees to free it. Remove the connector and rubber tube to replace.
    Good Luck!!
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I start the machine the suds flashes then it goes away and the F35 flashes and nothing happends I tried to use the clean washer cycle and it still comes up F35 then when I try to push the cancel button the...
If this is a steam unit you have a bad analog pressure switch,has been a common issue in those units,Gives an F35 core and sometimes a SUD code.
Sep 20, 2009 | Washing Machines
My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Aug 02, 2009 | Kenmore Washing Machines
What is code F35 on a whirlpool washer model wfw9600twoo
It's a general code for some electrical system problem. Ours flashes "SUD" before while the machine is on before flashing "F35" when it stops. I've tracked this done to being a problem with the pressure sensor switch in ours, and it appears to be either from obstruction from too many suds (like using the wrong detergent), or an actual sensor problem. I followed online advice to pull the tube and blow back to clear any suds out, and that cleared it for one cycle, but then the problem came back, so I'm either going to try some other things to clear before calling for a service person to replace the sensor. The part is W10156252 Switch, Analog Pressure Sensor, number 20 of the washer parts diagram.
Jul 29, 2009 | Whirlpool Washing Machines
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2009 | Kenmore HE2 Plus Front Load Washer
Sears Kenmore HE3 Error Code F35
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
