Question about Matsonic MS9158E+ Motherboard
Before I used motherboard that has VGA 512MB RAM 1GB CPU 26GH HD 80GB but now I want to use VGA 1MB RAM 2GM CPU 3.8GH HD 320GB how this motherboard can support all these components?
    Scholar:
  • 91 Answers
Well this depends on the compatibility of you RAM iff its DDR2 or DDR3 and with dual channel. for the processor you need to make sure that it supports you number of pins on the bottom of the processor and the wattage, harddrives you dont have to worry about much unless it a formating issue but i would check out here to get some really good info
http://www.newegg.ca/Product/CategoryIntelligence.aspx?SubCategory=343 Desktop learning center
http://www.newegg.ca/Product/CategoryIntelligenceArticle.aspx?articleId=194 Intel boards
http://www.newegg.com/product/CategoryIntelligence.aspx?Subcategory=22 AMD boards
Posted on May 05, 2010
I WILL REPAIR MY COMPUTER
Upgrade your RAM into 1GB or more, currently you are using 512MB which causes your system slowdown. On that model look for SoDIMM RAM with the DDR2 slot with 1GB or more. If you can see 2 memory slots, just buy additional RAM then put it on the blank slot.
Oct 06, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
Kind attention tech support, I have this CPU- INTEL Pentium 4 Processor, LGA775 Pkg, 2.66 GHz, 1MB L2 Cache, 533 MHz FSB MERCURY Main Board PNMCP73V, 1GB DDR2 667MHz Kingston DDR2 RAM SEGATE SATA...
You could put either of the graphics you mention in that motherboard providing you get the PCI-Express versions of them.
The motherboard will support a DDR3 structured graphics card in all cases at that is determined by the card not the motherboard as you get specific drivers for them which come included with the card or you can download the latest drivers from ATI or nVidia's support websites.
That motherboard will also support a gigabyte plus graphics card.
Kind regards.
Jul 13, 2010 | Computers & Internet
Motherboard repair
Best thing to do is to make sure only the CPU, Power Supply and memory are hooked up to the motherboard and then turn it on and see if you get video. If you don't get video then it probably is the motherboard that is bad and it wouldn't be worth your time spendingany more postage on it.
Also check the capacitors on your motherboard and see if any of them are bulging from the top, if they are then you might want to try and replace those with capacitors of the same value.
My feeling though is that the motherboard is bad and you would need to get a new one.
May 04, 2009 | Computers & Internet
How much Ram am I using?
Unless you are running a 64-bit version of XP or Vista, Windows will not report the full 4GB. It's because of the way the program addresses and uses RAM. Here is a page that gives a little explanation. The bottom line is that if you want to get the full use of 4GB of RAM you need the 64-bit operating system.
Apr 18, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
HOW TO FIND RAM CAPACITY OF INTEL D102GGC2
Intel D102GGC2 Motherboard Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
Maximum Memory Capacity: 2048MB
* Currently Installed Memory: 512mb Number of Banks: 2
* Dual Channel Support: Yes
* CPU Manufacturer: GenuineIntel
* Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Your MotherBoard Supports up to 2GB of memory.
You have 512mb, you can add 512mb to the empty slot.
, however,It's a good idea to keep them the same if you can.
You can install memory that is: DDR2 PC2-5300 (PC2-5300 is 667Mhz) you can use 1gb memory in each module for best performance and matching pairs since your motherborad supports dual channel.you can use sound card and SATA hard disk for higher disk support
Mar 15, 2009 | Intel D102GGC2 Motherboard
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
EMachine T6534 Ram Issue
did you try putting 4 1g stick . instead 2 1g and 2 512?
Jan 16, 2009 | Computers & Internet
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
With dvi monitor goes black for 2 second then comes back intermittently
To what I understand. Dvi and vga is only applicable to a system or CPU. Sorry if I am wrong.
Tia.
Mar 29, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Problem with pcx5750
Hi, sounds simple to me, Not enough RAM for what you are asking from your system. I would go to at least 1Gb RAM and if you can afford it 2Gb RAM, you can never have too much RAM but you most certainly can have too little. Regards mistyman
Sep 02, 2007 | Gainward GeForce PCX5750, (128 MB) Graphic...
Matsonic MS9158E+ Motherboard Logo
117 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
