Question about British Telecom BT Speedway (E4411) Modem
I have a bit of trouble with DM424X (British
I have a bit of trouble to run/test with DM424X (British Telecom) modem, I was wondering if you could forward me a copy of this modem manual. Because I have lost the one I had. Thanks
4 Suggested Answers
SOURCE: drive sungil telecom mini modem usb
I lost my cd drive sungil telecom. Where I can download it?
Posted on Nov 24, 2008
  • 175 Answers
SOURCE: graphite 1500 phone range out message comes on
your message box is full , you need to delete some of the messages from your inbox to remove this error message
Posted on Feb 20, 2010
SOURCE: British Telecom Freestyle 2200 Trio Cordless
I have this problem, have you found a fix yet?
Posted on Aug 23, 2010
Trouble dialling out - swamped by 'please insert coins on answer' message
inform the network provider
someone has hacked in and using to make free calls
let the network providers reset ontheir system
Nov 27, 2014 | British Telecom Contour 50 Corded Phone...
House phones not working no out or in coming calls
Phone 0800 800 151 to report a fault or use bt.com. There you can ask for a line test.
Nov 15, 2014 | British Telecom Synergy 2110 Cordless...
Get all deleted messages back from
simply insert the sim in the modem and regain all the messages u have deleted
Dec 01, 2013 | British Telecom Lands Phones
After talking for a bit the phone cuts off & says 'mute'
Sounds like the battery is needing a charge or a new battery.
Sep 26, 2013 | British Telecom BT BIG Button Corded Phone
Www.bt.com/producthelp
It's a British Telecom FREESTYLE 7100 1-Line CORDLESS HANDSET.
Sep 08, 2012 | British Telecom BT Freestyle 7100 Cordless...
Graphite 1500 phone range out message comes on
Feb 20, 2010 | British Telecom Lands Phones
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here -http://www.sohodata.co.uk/soho.htm But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –(http://www.btopenworld.com/broadband/adhoc_pages/driver_homepage.html#yahoodrivers) It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
Adsl connection
have the phone company check the line for "ring and tip" make sure they are the same as before, I suspect that the wire is reversed. the telephone don't care how the wire is run.
Nov 06, 2008 | Dynalink (V1456VQH) Modem
British Telecom BT Speedway (E4411) Modem Logo
48 people viewed this question
Top British Telecom Computers & Internet Experts
David Payne
David Payne
Are you a British Telecom Computer and Internet Expert? Answer questions, earn points and help others
