Question about HP Color LaserJet 2600n Printer
My HP Color Laserjet 2600n won't stop initializing, and both the orange and the green light are constantly flashing. Also, the printer toolbox on the computer indicates that all is fine, when it clearly isn't as nothing will print at all, not even a test or clean. It has been left on for a few hours as well as shut off for several hours to see if it would sort itself out, but its still the same. We also just pressed the engine test button on the back of the machine but still nothing happened.
Mrvica
  • 167 Answers
SOURCE: Print Problem in 2600n and Laserjet 1000
Just install 2600n manually and define as USB Virtual printer port!!!
Posted on Jan 24, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Posted on Nov 03, 2008
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
  • 47 Answers
SOURCE: hp color laserjet 2600n giving "10.0000 suply error"
10.00 error is for the black cartridge. Check the cartridge locker for the black toner cartridge on the right side, is it different from the other? does it moves correctly? check properly. If the locker seems correct, try clean the contacts on toner and opposite HV pins in printer
Posted on Nov 27, 2008
  • 81 Answers
SOURCE: where is laserjet 2600n toolbox?
Download the latest driver package from the HP website. This may help
Posted on Oct 13, 2009
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Where can I get the toolbox software for HP Color Laserjet 2600N for Windows 7 (64 Bit)?
Try this website:
http://www8.hp.com/us/en/support-topics/printer-installation/install-download-printer-drivers.html
Jan 15, 2013 | HP Color LaserJet 2600n Printer
When I open the toolbox for the LaserJet 2600n printer, it tells the website is not available. I need to clean the jets etc.
You need not to clean laser printer cartridges,it may color or mono. Print cartridges them selves having cleaning blade to clean the surface of the OPC drum every time when its initializing or printing. If you found any vertical tracks on print outs replace the particular cartridge.. If you have any kind of print quality issue,perform calibrate process through printer menu..quality..calibrating.. even if you found quality issue clean the Laser scanner assm.(professionals only can do)
Oct 28, 2011 | HP Color LaserJet 2600n Printer
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
I have an hp 2600n and a ibook 4g. yellow cartridge is empty and orange light is blinking. have printer settings to black & white, but won't print. help!
Regardless of whether you have printer set to print in black and white, these models will not function without usuable cartridges in all slots.
May 14, 2011 | HP Color LaserJet 2600n Printer
Cannot download software for color laserjet 2600n toolbox
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Nov 08, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n printer, flashing yellow light near printer cable
check the IP address on the printer,if u reset ur rooter it will assign a new IP so thats y cant print to it In a future use a host name of the printer so this wont happened again
Feb 23, 2010 | HP Color LaserJet 2600n Printer
Where is laserjet 2600n toolbox?
Oct 05, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600n giving "10.0000 suply error"
Nov 27, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
216 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
