Question about LG WD-14124RD Front Load Washer / Dryer
Torn door gasket / collar
I noticed that the collar/gasket around the door on our WD-1412RD washer is torn and needs to be replaced. Is this hard to do?? Is it expensive??
    Problem Solver:
  • 19 Answers
It requires technical expertise and speccial tools. Part isn't expensive, labor may be depending upon where you live
Posted on May 05, 2010
Lg intellowashet DD 7kg WD-1412RD. Won't start sometimes
it appears this type of washer is "sensing" what it may have inside of its self some washers will do this in this model type but if it fails it maybe a sensor not working as it should if its throwing an error code on its display
Sep 12, 2016 | LG Washing Machines
Model KSSC48MFS05
The door gasket may be bad or not touching frame check make sure nothing is in the way of door closing I like to unload and reload checking as I go .the gasket can be adjusted with a hair dryer but be careful not to over heat it you can melt or deform plastic if gasket is hard replace it or if it torn
Nov 02, 2015 | KitchenAid Refrigerators
Torn door gasket
it is possible for you to change it
it depends on where you are then could point you in the right direction
Feb 08, 2014 | Miele W4840 Front Load Washer
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
It leaks from the door how do i fix it? and is it expensive to fix?
The door gasket is most likely torn causing the leak. It costs about $110 plus labor if you are not handy enough to do the replacement. Indicate the exact model number of the washer for the exact replacement part number and detailed procedure on how to replace the door gasket.
Jun 08, 2010 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Model 587784100 My 18inch Kenmore apartment-sized portable dishwasher leaks when running and needs a new main rubber gasket (where the door seals the washer), and a new collar of some sort of white hard...
if you think you can do it then do it. it is normally not any harder than it looks. now because i work there i would say call them :) but you can change those parts fairly easily
Nov 25, 2008 | Kenmore Dishwashers
Leak from Bottom of door
Yes. It will get worst. However if it does not leak while you are doing your wash, then you are gravy for a while. However a replacement "bellow" is about $100 dollars.
Jun 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WD-14124RD Front Load Washer / Dryer Logo
106 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
