Question about Toro Lawn Mower With Toro Power Tools
How to remove the retainer blade from a Toro 20042 Personal Pace mower shaft?
4 Suggested Answers
  • 81 Answers
SOURCE: Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Posted on Jun 19, 2009
  • 202 Answers
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
sounds like the transmission engagment lever is broken or cracked. if you can reach the lever see if it has play when the cable is tight. you will need two people one to hold the lever and one to check the lever. easiest way is to invert the mower and have someone hold the lever on the handle. do not try this wioth mower running. the lever should be tight with the transmission lever engaged.another note here the clutch lever will not feel solid but kinda spongy. usually caused by overtightening the cable.
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: I have a Toro Personal Pace Recycler mower with a
It's not that hard. I've never done it on my Toro GTS 5.0, but I have done it on a Briggs and it's pretty much the same. Start by removing the 10mm bolts around the perimeter of the engine shroud. DON'T remove the 4 top bolts on the recoil housing. You might have to remove the fuel tank first. Drain it, then loosen the 2 8mm screws and lift it straight up. No need to disconnect the fuel line, just set the tank aside. After removing the 10mm bolts, the shroud should lift right off. Flip it over and you will see the recoil pulley. Remove any leftover cord from the pulley. Now you need to wind the pulley against the spring in the direction it goes when you pull the cord. It might wind 2 or 3 revolutions but don't overdo it. Now you will need some sort of clamp to hold the pulley in place as you line up the slot in the pulley with the opening where the handle goes. Next, feed the new cord through the opening and into the pulley and tie a knot to keep it from slipping out. Carefully release the clamp and let the pulley slowly wind the new cord onto itself. Finally, attach the handle on the other end of the cord and test it. If you can pull the handle and the cord comes out and it retracts normally, re-install the shroud and tank.
Posted on Oct 03, 2010
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
Where does the blade spacer go on a toro personal pace push mower
it goes: bolt, washer, blade accelerator, blade adapter in that order.
May 25, 2016 | Toro Garden
Replac drive belt 20068 personal pace with blade clutch
One belt runs your clutch the other runs your drive. there is a very small but thick belt which runs the clutch. longer belt for drive system
Jul 28, 2014 | Toro Garden
Toro push mover starts then quits
Looks like a fuel problem. Remove fuel line from carb., should get fuel.
Nov 25, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Toro Lawn Mower With Toro Power Tools Logo
188 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
