Question about Foxconn Computers & Internet
Does ''FOXCONN 8657MF-series'' supports 400mhz fsb of RAM
I have ''FOXCONN MOTHER BOARD 8657MF-series'' and also 256mb of ram with 333mhz fsb. Can i install a 1GB RAM with 400mhz fsb ?. Can i have the both i.e 256mb with 333mhz and 1GB with 400mhz.. ?
Thanks in advance...
  • 11,800 Answers
Yes, you can add it. The faster 1 GB will be downclocked to the speed of the slower 256MB.
 But it would be better for performance to remove the 256 MB one completely.
Posted on May 05, 2010
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
Problems with new ram
This = NO
The Foxconn P4M800P7MB-RS2H motherboard supports ram memory that is either 400MegaHertz, or 533MHz.
You have installed 667MHz ram memory.
http://www.play.com/PC/PCs/4-/3274794/-/Product.html
You also need to watch the Front Side Bus (FSB) of the processor you are using.
Ram memory typically operates at HALF of the FSB of the Processor.
Processor FSB support is 800MHz maximum.
Half of that is 400MHz.
You CAN use 533MHz ram memory, however.
(This is DDR2 Sdram ram memory.
PC2-3200 is DDR2 at 400MHz.
PC2-4200 is DDR2 at 533MHz. (Also known as PC2-4300. Depends on the ram memory manufacturer.
PC2-3200 actually operates at 200MHz. { Max} It is 'Dual Pumped'
PC2-4200 actually operates at 266MHz )
What to do?
Hopefully you saved the carton/s the ram memory came in.
Ship them back, get the ram memory you need.
ALSO;
What is the FSB of the Processor you have installed?
Don't know?
Post back in a Comment as to the model name, and model number.
(Example; Intel Pentium D model 805,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Smithfield.22_.2890_nm.29
FSB support is 533MHz
No, you cannot use 533MHz ram memory. { PC2-4200 }
PC2-3200 is the max.
Pentium D model 820 for example, you can )
Nov 18, 2011 | E-Machines Computers & Internet
1.Suggest me the type of ram which is supported Foxconn 8657MF-series. 2.When i installs DDR400 RAM of 256MB it gives continuous beep(bee-bee-bee) sound. 3.What are the beep codes of Foxconn...
the beep sound on system starting before booting starts refers no RAM in system, if you need to upgrade your RAM then go for DDR-SDRAM PC3200 200MHz 512MB 0r 1GB.
Jan 24, 2011 | Foxconn (865G7MC-ES) Motherboard
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
How do i change the memory bus speed on my dell optiplex 170l? The CPU is an Intel Celeron 2.4GHz. The mother board processor speed is 400MHz and the Bios indicates a memory bus speed of 266MHz and does...
You checked in the right place as far as looking in the BIOS, however, memory and CPU sockets do not necessarily have the same buss speed. My FSB runs at 1066Mhz and my RAM at 800Mhz, it all depends on what type of RAM you buy as to the bus speed. You can up the bus speed on your RAM if you wish to reduce bottle-necking, but I've only done that a few times. In order to adjust anything, you must set the settings to manual. Be careful when you change this stuff around though, voltages must also be adjusted accordingly.
Feb 28, 2010 | Dell OptiPlex 170L PC Desktop
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
RAM running slowly
hi there
this is very interting you are asking for fsb to adjest at 333mhz.
for this first you have to look your prosser fsb , *********** board fsb and your ram fsb.
fsb is a front side bus on which data ia is running at speed but for high speed you have to increase your fsb you are askin (ie:333mhz). itell you how?
example : your prosser fsb is 266mhz
your ram fsb is 400mhz as you told
*********** board fsb is 333mhz
now you system fsb is constant on 266 mhz because system on that fsb witch supporting by ram prosser and mobo( motherboard).
if you want to increase the fsb you have to buy mobo, ram,and prosser at same fsb.
Aug 15, 2009 | Dell Dimension 2400 PC Desktop
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1558844&CatId=1600
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
Motherboard query
If this is your board, it only has DDR support upto DDR400 (pc3200) upto 2gig, not DDR2 support.
All the rest of the specs are on the page anyway, so pointless repeating them all.
Apr 16, 2008 | Foxconn (865G7MC-ES) Motherboard
Can i use DDR2 RAM in intel 865GBF motherboard?
NO ! you can only use DDR 1 ram (266Mhz,333Mhz,400Mhz) speeds only
Mar 30, 2008 | Intel D865GBF Motherboard
Computers & Internet Logo
894 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
