Question about RTO Gas Motor Scooter
50cc stop working after three miles, brand new, delivered today
Got the 50cc motor scooter delivered today, put fuel and oil in, then went three miles, then it die
Another thing you might want to do is get a new spark plug, they only cost like $5 because the ones they put in at the factories are Chinese bull
Posted on Jan 18, 2013
  • 45 Answers
Have you checked that the spark plug is tight and that the ht lead is on the spark plug?
Posted on Sep 03, 2010
My 50cc scooter won't go over 30mph
Hi, Bob and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help Ruck won go above 30mph Thanks
Advice please 49cc won go over 20 mph
gy6 50cc to 100cc bbk upgrade still wont go over 30mph It Is The Ride
My scooter won reach top speed anymore scooters
SCOOTER WONT GO OVER 20MPH HELP
Mar 28, 2017 | GAS Motorcycles
My 50cc Scooter has a brand new carb but gas is leaking from overflow ???
Hi, Kim and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Carburetor is leaking gas out of overflow tube need help
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://www.49ccscoot.com/manuals/Hyosung_SF50_Service_Manual.pdf
50cc scooter parts QMB139 49cc 4 stroke parts moped parts QMB139
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Jan 04, 2017 | Motorcycles
How to refuel a sym jolie 50cc scooter, do you mix oil into the petrol tank, or do you fill the oil and fuel seperatley or does it mix it itself????
Pretty much all are normal petrol in the fuel tank and the oil is on another tank. The oil is mixed as it enters the inlet manifold.
Your manual is here. Section 2-3
ScooterCommunity
Nov 06, 2016 | Sym Motorcycles
Keeway matrix 50cc scooter cuts starts to cut out after it gets warmed up
CHECK VOLTAGE WITH VOLT METER AND GAS/OIL MIX COULD BE RUNNING ROUGH
Apr 10, 2013 | 2006 Keeway Matrix 50
Hello i have a Generic Ideo 50cc scooter, last night i spotted an oil leak the tube had come away from the carburetter and i carn't see where to reattach it. I said take it to a mechanic but my dad...
Most 50cc bikes have three tubes plus a fuel line from the gas tank to the carb. There should be a tube from the battery, a tube from the carb and a tube from the gearbox. All three tubes are just vents to the atmosphere. Chances are the tube in question is the one that vents the gearbox, hence the oil. Please rate my answer.
May 24, 2011 | Generic XRace 50 SM Motorcycles
Just got eagle milano 50cc manual is horrible. how should the dip stick look with proper oil level? What weight oil should I use has 245 miles on it Mfg is Bashan
You should put in approx 900 ml of 5W30 or 10W30 engine oil. Make sure the oil level on the dipstick doesn't get onto the plastic. As long as it's on the metal, it's good.
Apr 28, 2010 | RTO Gas Motor Scooter
No power
Keep changing parts until you find the solution! No, just kidding. Many will do this if they don't understand how an engine works. It sounds like it may be a hung choke. Engines need extra fuel when cold, and die when warm if they are still getting that extra fuel. Also, low oil level will give the same indication. There are many variables.
Nov 22, 2009 | RTO Gas Motor Scooter 50cc
Direct bikes scooter wont start
you need to have some fuel in the system over night as when it is shipped it is completly dry when this is done it should start with out any problems if it still has the same problem then you will need to charge the battrie
Nov 02, 2009 | 2004 Factory bike Chrono SM 250
How to pre-mix 2-stroke
the recommended mix is 40:1. So for 5 liters of fuel you're looking at 4.2 ounces of oil.
May 27, 2009 | Peg Perego Vespa Scooter
Scooter losing power in moving forward when stopped at stoplight. Also, loses power en route. Reached 350 miles on odometer. Went to change engine/gear oil. Took off ''oil pan'' screw. Only ~<50 mL came...
Check your jets in your carbs and also could be bad fuel. Poor some sea foam in it and some new fuel and check to see if the inline filter is plugged and check your air filter as well.
May 09, 2009 | 2007 Bajaj Pulsar 150
RTO Gas Motor Scooter Logo
822 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
