Question about Neff B1421 Electric Single Oven
Oven trips out main electicity supply moments after switching oven on
Oven trips main house fuse as soon as it is switched on
Posted on Jun 14, 2010
  • 523 Answers
Try replaceing the breaker first.
Posted on May 06, 2010
Why has our oven stopped working whilst cooking - nothing electrical seems to be working?
Did you check your electrical breakers? Maybe it tripped. Reset it by first switching it fully to the off position, then switch it to on.
Feb 29, 2016 | Ovens
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 07, 2011 | Smeg Ovens
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
HotPoint model# RB787WC4WW : Clock is functioning, all lights are on, but the burners and oven won't function. Is there a fuse or relay on this model ,and if so where is it located. I've taken the...
your oven may be on a 3 phase connection that mean you have 3 supplies to it.
one phase may be running the clock and fan etc.
the other two maybe for the burnters .
check in your house fuse or trip switch box and ensure that all trips are on and or fuses are not blown. this is usually where your electic meter is located.
if this is the case switch the circuit back on, if the fuse goes again this may indicate a fault either in your home or with your oven. if so call in an expert to check.
warning. high voltage electricity is dangerous if unsure call out a qualifed electrician or speak to your electicity supplier for advice.
i hope this was useful
Dec 11, 2010 | Hotpoint Ovens
Belling XOU70FP tripping the mains supply, any suggestions ?
Strange that it does not blow a fuse. Is it tripping the main switch or an earth leakage switch? There is obviously a short circuit and you need to call an electrician. It could be an element, but lacking more specific detail I would be guessing.
Sep 06, 2010 | Ovens
Power tripping off at mains when switching oven on
It will probably be the main oven element that has failed.
This is located at the rear of the inner oven compartment behind a removeable cover.
Jun 03, 2010 | Neff B1641 Single circotherm super...
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Neff B1421 Electric Single Oven Logo
368 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
