Question about Arris SURFboard SB4200 Modem
Runs for awhile shuts down alot
It runs for awhile shuts off .
    Problem Solver:
  • 19 Answers
Change mac address
Posted on May 06, 2010
P0301 code on vw beetle
may need fuel pump replaced. have a pressure test done on fuel system to see if that is the problem. In alot of cases a weak fuel pump that has not gone out completly will fun fine at first then after awhile will shut off. In some cases it will run fine and just shut down. Usually after awhile of setting it will start again and do it all over again. hope this helps and good luck
Aug 13, 2012 | Volkswagen New Beetle Cars & Trucks
Runs for awhile shuts down and will restart but will run awhile and shut down
Check your oil, you have a low oil sensor on your unit and if the low oil sensor will shut the engine down,
Aug 28, 2011 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
1990 Honda Civic,Car wont start after its been running for awhile, then it starts after it cools down
You have a common problem; back in the early 90, the distribtors assemebly was causing alot of shut down problems for Hondas, the pickup assembly inside the distibutor would become hot and stop producing sparks/ engey to the sparks plugs. When cars came into the shop we would most of the time just replace the distributor assembly, but they can be kind of expensive thought, if you live near a salvage year it may be your best option for getting a good used one.
I hope this helps.
Rodney
Jun 14, 2011 | 1990 Honda Civic
Keeps shutting off
You cant clean the HEPA filter.. only the blue washable pre filter.
Sounds like the motor is dead or atleast on its way out.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
89 f150 runs good when cold shuts off after 20 miles and then has to sit for awhile before it will start and run properly then only runs a short distance and shuts off again. It sounds like its trying to...
It will be either the pick-up coil inside of the distributor is malfunctioning, the Dura-Spark Control Unit is faulty, or the wiring to and around the Dura-Spark Control Unit and running out to the engine is faulty. (I always find these wires on those year Ford trucks to be in very poor condition with a lot of missing wire insulation allowing the bare metal wires to touch each other or to short out on the body ground) The wires should be inspected very carefully and also be certain that you inspect inside of the wire looms for any damaged wires.
You might be able to remove the Dura-Spark Control Unit and have it tested for free at most auto part stores.
Jun 11, 2010 | 1986 Ford F150 SuperCab
Can you help me
the fan only comes on when needed. the fan in my 92 would run alot in summer but i would never hear it any other time of the year. my jetta also had the oil light problem i was told it is the oil level indicator i drove the car for 6 years that way until i crashed it.
jattas are great
Oct 30, 2009 | Cars & Trucks
Nothing inn the canister after using,suctione working,bottom roller working,no air leaks from hoses.Also when running awhile it shuts off by itself,have to wait awhile to use again
I'm not sure what vacuum you have, but that sounds like a blockage to me. Thermal shut off kicks in, shutting the motor down, to prevent damage from overheating. After waiting like 1 hour it probably comes back on. Make sure hose, filters, bag (if any) is clean. All "airways" of vacuums need to be clear of any blockages, since airflow is what makes vacuums work.
Apr 18, 2009 | Vacuums
Blue screen and windows shut down
For the issue of BSOD of Unmountable Boot volume, the only solution so far is to reinstall the system. If you are unaware of how to do it, it would be easier to contact Dell technical support and allow them to guide you thru it. (if your warranty is active, it's free)
Dec 21, 2008 | Dell Inspiron 6000 Notebook
Powers down
this set is known for the deflection and convergence causing the set to shut down ,watch for clues as where to begin, inspect the neck boards also for arcing as well as the flyback trans former,listen for arcing upon shut down.
Nov 16, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Arris SURFboard SB4200 Modem Logo
250 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
