Turntable problems i cant get my pioneer pl990 turntable to work on my kenwood or a sony receiver. it uses one channel and will knock you down with the volume level. However I can make it work hooked up to an old Montgomery Wards system. Can you help me
  • sunnyjackson Mar 30, 2008
    I actually found out the cartridge is also amplified so you need to plug the rca jacks into an aux or a different input than phono, because from what i read the phono input is also amplified causing the extreme volume and distortion. plugging it into the tape input worked ok.
    Allen
  • 4,234 Answers
I don't quite understand what you mean by "knock you down". The RCA plugs shouldb e connected to a phono input. If you don't have one, you will need a phono pre-amp.
Please update this if you still have questions.
Dan
Posted on Mar 26, 2008
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Dec 13, 2014 | Pioneer PL-990 Turntable
Hello. Just bought a pl990 and trying to connect it to creative speakers for the meantime. Im using a female rca plug but the sound wont come out in the speakers, nor is it working on my pyramat chair or...
The problem is that the output signal from a phono cartridge is very low. A turntable is meant to be plugged into a receiver or amplifier with a turntable input designed for that level. An auxiliary input on an amp is made for a higher "line-level" input. To use a turntable with a line-level input you need a preamp (here's a typical model at Amazon.com) to boost the signal to the amplifier. Then you'll be able to play your records and hear them.
Jul 02, 2011 | Pioneer Audio Players & Recorders
My pioneer PL990 turntable, the pitch wavers.
try cleaning the inner ring on the underside of the actual turntable platter and also the motor spindle using isoprynol alcohol or use neat clear spirits like bacardi/vodka with cotton wool etc. if black residue comes off either the platter or the motor spindle that will be residue from the old belt that could cause the fluctuation in speed? good luck.
Jul 10, 2009 | Pioneer PL-990 Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
How to hook up a turntable to a stereo
you might need a pre amp in between the turntable and the kenwood.. but you'll connect this on the aux IN.
Aug 05, 2008 | Audio Players & Recorders
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
Pl990
The turntable does not turn. There is a black rubber band type that needs to be looped around the gears. How do I do this?
Mar 26, 2008 | Pioneer PL-990 Turntable
Trouble with sound
Confirm that the stylus you bought is spec'd out for that turntable
Also check all four wires to the cartridge
Mar 13, 2008 | Pioneer PL-990 Turntable
87 people viewed this question
 Grubhead
Grubhead
