How to take the washer kenmore apart to change the lid switch.
  • 5,911 Answers
If this is a Kenmore top loader, the following link explains step-by-step how to access and replace a lid switch:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
If you have any questions about this repair, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on May 05, 2010
Kenmore washer model 110 26712690 fills up with water and does nothing. wife said she smelt something burning. I thought maybe a belt but when I took it apart I didnt see any belts.
no belts in a kenmore,if it filled with water and stopped most likely you have a bad lid switch.close the lid,open it up a few inches and close it down a few times,if you don't hear a clicking sound every time you open and close it the lid switch is bad.,if you already have it apart,you can jump it out,the white harness you disconnected next to the right clip is the lid switch harness,stick a wire in the two outside holes,put it on spin and pull the timer out,it will run.the model number you sent isn't correct,i was gonna give you the part number and price of the switch,just give it to your parts store and they will sell you the correct part.
May 15, 2011 | Kenmore 22422 Top Load Washer
Washer quit working in rinse cycle before spin cycle tub full water does nothing but fill with more water when you increase water level
99% of the time the lid switch is what causes this issue, below are two links one where you can get the lid switch and the other explains how to take the washer apart to test and access the washers lid switch.
Cheap Appliance Parts Click Here
Good luck with your repair!
How To Take Kenmore Washer Apart Click Here
Mar 05, 2011 | Kenmore 26882 Top Load Washer
Agitation does not stop when lid is open... Kenmore 20172 Top Load coin-op Washer needs new lid switch? Cost? Easy to Fix? Do I need a expert to do? Thank you...
sounds like the lid switch is jammed on- you can try to spray it with WD 40 or replace it it usually requires taking the machine apart to get at the wiring. Easy fis, just need patience. the switch should be able to be ordered online.
Oct 21, 2010 | Kenmore 20172 Top Load Washer
Lid switch on a 20802 kenmore washer
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Can't figure out how to get the washer apart to put in the lid switch.
If this is a Whirlpool made machine (which includes Sears Kenmore), there's a video here showing how to get the cabinet off for different models.
Apr 25, 2009 | Washing Machines
Getting to lid switch on kenmore washer to replace it
This can be done without taking anything apart or removing anything except the lid switch.
Take the two screws out that holds the lid switch and let it drop into your hand. You may have to pull a little if it doesn't drop down on it's own. You may also have to push the tub over to get to the lid switch if you have big hands.
Dec 24, 2008 | Kenmore Washing Machines
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
