Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Surge Protection I believe
It blinks 6 times with a pause, and it sounds like some switches on the power supply are switching off, but then immediately turn off again.
  • SonyHomie
    SonyHomie Mar 26, 2008
    *switching on, then immediately turning off again
  • backnefct May 11, 2010
    I am having the same problem with my Sony KP53HS30. I have no picture and sound and see the 6 blinks. Is this an easy fix? Where do I find a repair manual. travisllee@yahoo.com
    Thanks
    Trav
  • Sony Master
  • 8,617 Answers
Your set is experienceing low B over current or over voltage tripping the protective shutdown. Indicated by 6 blinks. You will need to check the +5 line on the A and B boards for being over loaded or shorted. If you would like the service manual for this set and be able to recieve free tech support with manual purchase. let me know and I will post a link
Posted on Mar 26, 2008
My panasonic plasma model# TC 50PX-14 powers on flashes 6 times pauses then flashes 6 times again.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 01, 2017 | Panasonic Televison & Video
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Standby light blinks 6 times pause and blinks again
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 05, 2014 | Sony KDL-52XBR9 52 in. LCD HDTV
I have a sony kdl-52v4100 tv. It had a power surge and now blinks 2 times. I changed the power supply with a known working one and it burnt it up. I changed the power supply again and the bu main boar
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 03, 2017 | Sony Bravia V-Series KDL-52V4100 LCD TV
My sony kv-32hv600 has a red Stand By light blinking 6 times and then it pauses and blinks 6 more times. Is there any way I can reset it so that I can use the TV again. There is no picture or sound coming...
No the blinking lights are an error code with an issue and that protects the TV from further damage.
I believe that is a power supply board failure code. Time for repair! Sorry! Take it in for service or you may try to repair it yourself.
Oct 10, 2010 | Sony Televison & Video
Mitsubishi non powerup problem
If it is a steady blink then it will be something with the microprocessor not resetting. That set does give fault codes by blinking in a pattern, like two blinks then a pause then three blinks.
It can be a little tricky to troubleshoot, I think that set has a micro, two eproms and another IC that they called a watchdog which has a lot to do with the micro and preventing it from locking up. It may also be a power supply problem not supplying proper power to the micro. I'd try a few more unplugs and maybe plug direct to outlet and bypass surge protector. If it won't reset you'll need someone familiar with that set to service it for you.
Jun 19, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
5 blinks 1 second apart No memory
6 blinks 1 second apart No graphics
7 blinks 1 second apart System board failure (detected prior to video)
8 blinks 1 second apart Invalid ROM
Nov 07, 2007 | HP Compaq Business d530 Ultra-Slim PC...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
