Question about Acer Aspire 3680 Laptop
Must have deleted something that i shouln't have and now cant make my dvd/cd to work please help me out.
  • alro790 Mar 28, 2008
    It still wont work an it says " this device cannot start ( code 10)
    How do i fix this. Please
    Genius:
  • 3,587 Answers
Ok..go to start, control panel, system device manager, and see if you can 'see' any dvd or cd devices..if not, just do a scan for hardware changes, and see how that goes.
if not, go here, and find the acer logo, and get a new set of system drivers.
Posted on Mar 27, 2008
My Sony CRX320EE-88 cant read bootable cd/dvd. Yes it registers at the bios on boot up and its also detected on my windows start up but when it comes to playing cd's and dvd's, it cant read both of them....
make sure that the cdrw/dvd rom is getting enough power test all leads that are attached to the cd/dvd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 04, 2011 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
When i put a blank cd in the cd rom of a dell computer it spins a couple times and makes noise when it spins like it is hitting something and then it stops spinning!!!!!! PLEASE HELP!
make sure all leads that are attached to your cd/dvd floppy drives have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 04, 2011 | Dell Computers & Internet
Windows Media Player 11 does not recognize my HP DVD/CD Burner..
WMP cant recognize it.The OS (WIN XP) is the one .So!
1-Uninstall the burner driver
b-Do a system restore
b-restart
Install again! Good lock!
Feb 23, 2010 | Creative Labs Blaster CD-RW 4224 Burner
I cant load anything or play anything as my cd dvd seems to have disappered, i have been in the bios and cant find anything that showes how to sort this.can you help me please. w mc kinlay.
This may happen due to some improper connection to your hardware and may also due to device disabled in BIOS.
Soultion:
1. Enter into BIOS setup by pressing Delete key during system startup and load optimized default settings. Shortcut key for this may be 'F7'
2. If not works, then open the PC cabinet and check the bus connected to the drive. Replace it if neccessary.
3. If driver is shown in my computer but not reading cd/DVD, then use a lens cleaner cd to clean the lens surface dusts.
4. If it not working still, then its time to give it for a service.
I hope this is helpful to you.
Nov 07, 2009 | Televison & Video
Cd dvd burner is not working
Is it not working or not being seen in windows. If you cant see it in windows there seems to be a Windows update or something that is making peoples CD / DVD drive dissappear. If this is what your experiencing then try this fix:
http://icompute.info/cd_drive_not_in_windows.htm
Hope this helps...
Oct 18, 2009 | Acer Aspire 5610-4648 Notebook
DELL Inspiron 6400. CD/DVD ROM cant read any cd/dvd used to work before but not working anymore. updated the firmware from Dell website, done the upgrades etc.. still doesnt work? help please.
If the drive still spins up when you insert a disk it sounds like the lasers have picked up dirt/dust or have burnt out. Try opening the drive door and blowing hard into the aperture (without spitting). If that doesn't help then I would suggest replacing the drive. I assume that you have tried the disks in another machine and that they run fine.
Jun 07, 2009 | Dell Inspiron 6400 Notebook
Problem with CD Drive
try rolling back your pc if not try puting a old or new dvd or cd drive in
Nov 12, 2008 | Compaq Presario Notebook
Pioneer dvd writer problem.
sometimes it depends on what kind of dvd-r you buy because they have DVD+R DVD-R DVD-DL ect it might also depend on the brand of the dvd-r most of the time the more exspencive ones work better Like sony or memorex
Oct 27, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
My region codes on my dvd burner have been changed and i cant change them again how can i fix this or do i need to buy a new one??
the drive allows you change the code 3 times and if that is already done ... than you can try to update the firmware ... and in case tht doesnt work u have to buy a new one
Oct 22, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Canon dvd camcorder dc201
I am not sure if this will work but at least you could give it a chance..try to use ALCOHOL , DAEMON TOOLS or something similar to make a dvd image on your computer, then burn it on to an appropriate formatted dvd.
Aug 27, 2008 | JVC 20GB Everio GSeries HDD Digital...
Acer Aspire 3680 Laptop Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
