Hooking up a tv ,vcr ,cable box for maximum efficency
  • Anonymous Apr 07, 2008
    I purchased a new DVD/VCR with no input for cable. How do I hook the cable to the DVD/VCR? My TV has a red and white input on the back.
I cant get cable 2 my magnavox tv what do i do
Posted on Apr 16, 2008
SOURCE:
How to hook up vcr when using a cable box
That will depend upon what you want to do. If you plan to record to the VCR from the cable box, then the cable box will need to directly connect to the VCR, then the output of the VCR is connected to the TV. Unfortunately, most VCRs are analog, not digital, so you will lose HD capability (if you have it) trying to connect this way. You also cannot record one show while watching something else (you will need to be tuned to the channel you are recording). If you want to simply use the VCR to view recorded tapes, then connect the cable box to the TV as per the cable company recommendations, and then make a second connection for the VCR. Of course, your TV will need appropriate and available jacks on the rear to do this. It is difficult to give specifics without knowing the models of the cable box, VCR, and TV.
Sep 15, 2015 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
I'm trying to hook up my vcr to my digital box and tv. I think that I have the connections right but when I try to record a tv channed it doesn't record. What am I doing wrong? Or how do I hook up my...
Make sure your VCR is on channel 3 or try channel 4. Also, make sure your VCR is set to VIDEO or VCR and not TV.
A better way to do this is to connect the cable box to the VCR using the composite cable (yellow/red/white) cable. Then, connecting the cable box to your TV with component cable (red/greenblue) cables. This will only work if your TV has component in. If not, then connect the VCR out composite (yellow/red/white) to the TV. Or use the coax cable from the cable box labeled TV/VCR right to your TV. Make sure your VCR is set on LINE1 or LINE.
May 02, 2009 | Memorex MVR2031 VHS VCR
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Vcr hook up
Have you tried to run:
Coax from the wall to your cable box.
Coax from the cable box out to the VCR cable in.
Coax from the VCR cable out to your TV?
What connections does your TV have? RCA or coax?
Mar 21, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
At the end of my wires
If you use scart cables you almost cannot go wrong. You can either hook one scart from your DVD/VCR to the TV and one from the cable box to the TV, and switch using the A/V button on your TV.
Alternatively, you can hook one from your cable box to the "in-port" on your DVD/VCR, and one from the DVD/VCR to the TV. In this case you should be able to record programs from your tuner.
Dec 11, 2007 | Toshiba 27A44 27" TV
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
Ekse
