Question about Brother MFC-6890CDW Printer
Unable to clean
The screen shown unable to clean but no paper jam etc.
  • 4,041 Answers
Hi there you can try
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times until the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. Press the stop/exit key to return to the initial stage of the maintenance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 05, 2010
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
DCP-J125 Uable to print (36)
The message Unable to Print (followed by a two character code) will appear on the display for one of the following reasons:
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper, stuck in the machine
- Mechanical malfunction
The most common cause of the issue is dirt on the encoder strip. Clean the encoder strip by doing the following:
CLEAN THE ENCODER STRIP
NOTE: The images shown below are from the representative product. The customer's model may look different from the picture.
1. Locate a lint free cloth such as a T-shirt, DRY eye glass cleaner cloth, DRY monitor cloth or wash cloth.
DO NOT USE ANY TYPE OF PAPER PRODUCTS (EX: paper towel, tissue paper, napkin, filter, news paper etc.) This will help ensure the dirt is removed from the encoder strip.
CHECK FOR FOREIGN OBJECTS & PAPER JAMS
2. After thoroughly cleaning the encoder strip, look inside the machine and in the two corners for jammed paper or foreign objects and remove them if any are found. Pieces of paper may be jammed under the print head.
If the print head is locked to the right side of the machine, press and hold the STOP/EXIT key for 5 seconds. This will cause the print head to move automatically to the middle of the machine and allow you to look for debris in the right corner.
3. Leave the scanner OPEN and turn the machine around so you are looking at the back of the machine.
4. Open the Jam Clear Cover and look inside the machine for paper. Remove any jammed paper that appears; then close the Jam Clear Cover and turn the machine back around to the front.
5. Gently close the scanner cover and verify the error message cleared from the display.
If you cleaned the encoder strip ONCE and the message continues to appear on the display, clean the encoder strip again. It is common to clean the encoder strip multiple times to resolve the issue.
If you cleaned the encoder strip at least TWICE and the message continues to appear on the display, unplug the machine from the power outlet for 2 seconds and plug it back in to cycle the power.
TEST THE MACHINE
NOTE: After a paper jam has been cleared, the Brother machine may complete a 2 minute cleaning cycle to remove paper dust from the nozzles before printing.
May 01, 2012 | Brother Office Equipment & Supplies
Unable to Clean 5A
The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam, try to clean the sensor on the top of the printhead.
Mar 03, 2012 | Brother MFC495CW
Desk jet 2360 cradle thrown left and right repeatedly then cradle jams.repeated errror codes of catridge,paper jam etc
Unable to find the encoder by the carriage assm, clean encoder & encoder reader sensor. (encoder is just like a film printed with lines on it, located behind the cartridge carrier)
Sep 12, 2011 | HP Deskjet D2360 InkJet Printer
Ix4000, paper feed jamming all the time
To clean your Canon Pixma > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
This will solve the paper jamming problem. Hope this helps, please rate if the solution was helpful, thanks!
Sep 02, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
My brother printer model is mfc-685cw. i checked paper jam but my lcd screen say unable to print 50. I am unable to shut down also.Then i switch of my printer after one hour i started but again i saw same...
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
http://www.fixya.com/support/t227515-printer_paper_jam_brother_mfc
Sep 01, 2010 | Brother MFC-685cw InkJet Printer
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-6890CDW Printer Logo
223 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
