Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso Washer
I had a load of clothes in and at some point it just stopped and was flashing 5L. I wasn't home at the time, so I don't know if it made any noises first, but when I tried to restart it (it's full of soaking wet clothes, I think it was going into the rinse and/or spin cycle) now it makes a weird buzzing noise after about 60 seconds of filling up and then when I turn it off, it sounds like a motor winding down. Still flashes 5L. Help! Thanks!
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Posted on Apr 15, 2008
Dryer is growling when spinning heavy loads.
The bearings may be gone, but I don't know how old your machine is or the brand. If it is over 8 years old, consider replacing it. Maybe get an estimate from a repairman who knows your brand.
Jun 09, 2015 | Dryers
GLEH1642DS1 FRONT LOAD STACKABLE WASHER MAKING LOUD THUMPING NOISE IN SPIN CYCLE & SQEALS WHEN i STOP IT
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
2005 chevy optra hatchback. Engine making loud ticking noise and the check engine light is flashing on and off. When driving, feels like it's about to stall, and uphill is a struggle.
Check your timing belt, even if your only symptom is loud lifter noise on startup. The belt/pulleys are not designed with deep V grooves and the tensioner is manual, not spring loaded. If the crankshafts stops at a certain point and creates any slack in the belt to the top right lifter pulley, that pulley, under tension from the spring loaded valves, tends to jump a notch. The only solution, after refixing the timing belt correctly (make sure you know how to do this) appears to be careful over-tightening of the manual tensioner and prayer! Bad design.
Oct 23, 2012 | Cars & Trucks
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
My Bosch Maxx (probably about 7 yrs old) was working perfectly till I opened the filter compartment (bottom right) to check it wasn't blocked. It wasn't. Put it back. Next time used machine there...
Bosch Maxx This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 28, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Bosch exxcel 1400 express
unplug the device from the mains for few minutes then check out many a times it clears the fault.
Apr 21, 2008 | Hotpoint WMA44 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
275 people viewed this question
Dan Webster
Dan Webster
Sal De
