Question about HP PSC 1315 All-In-One InkJet Printer
How do you scan a multipage document into the computer
  • HP Master
  • 12,061 Answers
Ok get a software ScantoPDF,
www.snapfiles.com/get/scan2pdf.html
http://www.giveawayoftheday.com/scan+to+pdf+freeware/
Also. when installed properly you can scan pages into word, you do this by Going INSERT PICTURE, then from Scanner,
Posted on May 05, 2010
3 Suggested Answers
SOURCE: I have a hp office jet 5610 with document
The way to fix this is to do the following: lift the lid, clean the glass with window cleaner and a paper towel. (WARNING! Spray window cleaner onto the paper towel not the glass. Spraying directly onto the glass could cause you to get shocked or worse short out the officejet.) Wipe glass with dry paper towel.
On page 112 of the owner's manual it shows how to open the document feeder. Spray some window cleaner (just to were its damp) onto the swab and gently clean the the glass. take a paper towel and dry the glass.
This should take care of any lines on scanned images.
David
Posted on Jul 22, 2009
  • 158 Answers
SOURCE: i cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
2.select scan setting
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Posted on Nov 20, 2009
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I have lexmark x7170 and windows vista with microsoft 2007...If I try to print a range of pages out of word, it prints one page, then deletes the priting on the rest. I've tried to re-install the driver a...
Hi. Lexmark has a patch for
resolving problem like printing a
multipage document. Here's the
link to the patch.
http://bit.ly/aMwdWR . Click on
patchformultipageUACissue2.0.exe .
Run the software in your computer.
Try printing a multipage document
again. Hope this resolves your
problem. Good luck!
Mar 14, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
When scanning a document, such document stays with the previous document scanned and wont save as a different file. How can I separate what I'm scanning from what I scanned previously on my computer? How...
If you had selected 'multipage' option, the scanner will convert all pages into a single page. Switch off (uncheck) multipage option and you will get individual page outputs. Check in the software if your clicked unnecessary button for saving in the last file. Try 'Default' button if available and try again.
Oct 16, 2009 | Bell & Howell B we Bell + Howell Truper...
I need to scan a document to one file. My scan is
If you have created a Directory and the scanner is saving every scan there as a .jpg or similar then it is doing what is is paid to do
To create a multipage document you need to do it as a .pdf or a.tiff
Try using Adobe Reader 8 or similar
Products to make multipage files are available on www.filehippo.com
Jun 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Scan a Multipage Document into a Single File
My scanner is a Cannon but the basic jist of what your trying to do is universal. You need to open up the software for the scanner and look for an icon that says scan to file. It sounds like you have already done this. If so you are very close in the step I mention to the setting you need to scan multiple pages into one PDF file. Once you find the setting to scan multiple pages be sure to not click "FINISHED" until your last page is scanned in.
LB
Nov 30, 2008 | HP ScanJet 2400 Flatbed Scanner
Scanning multiple page documents
Yes you can. You need a small scan application whitch allows you to scan multipages.
There are for example ScandAll21 from Fujitsu (freeware) or PaperPort 11.
http://www.opendrivers.com/driver/229211/fujitsu-scanners-scandall-21-v4.2.34-windows-free-download.html
http://www.nuance.com/paperport/
Jul 18, 2008 | Epson Perfection 1250 Flatbed Scanner
Scanning
What software are you using to scan? Some software programs aren't really geared towards multipage scanning, while others do a good job (OmniPage for example).
Mike
Nov 08, 2007 | Dell 1815dn All-In-One Laser Printer
HP PSC 1315 All-In-One InkJet Printer Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
