Question about Electrolux EOB5610 Ultrafan Electric Single Oven
My Electrolux EOB5610 fan oven will not heat up. Turning the selector to on the power light comes on, but when you adjust the heat setting the temperature light does not come on (this usually comes on and stays on until the oven reaches temperature). The internal oven light does not come on, the fan does not spin and the heating element does not heat up.
  • 523 Answers
Replace t stat
Posted on May 06, 2010
My electrolux EOB5610 wont heat up....the fan works and the grill works but will not reach any sort of temp !!!!
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 02, 2011 | Electrolux EOB5610 Ultrafan Electric...
My Electrolux EOB5610 fan oven will not heat up. The power light is on. The oven light is on. The fan works. There is some heat in the oven but not enough to cook with.
Only two possible causes. The oven element is faulty or the oven thermostat controller is faulty. Probably the first thing to do is test the oven element and check the resistance. If the element is okay then the oven thermostat will need replacing.
Feb 23, 2011 | Electrolux EOB5610 Ultrafan Electric...
My Electrolux EOB5610 fan oven will not heat up. Turning the selector to on the power light comes on and the oven light comes on. The fan is working but heat not getting hotter.
Sounds like you element is faulty. You can check it by removing the panel in front of the element which is held on by 4 screws then you can visually check it to see if it has blown. If it looks ok then unscrew the element and carefully pull it towards you a couple of inches, this will allow you to pull the 2 wires off, make sure the wires dont fall back inside the machine or you will need to remove the back panel. The use a multimeter on the buzzer or sounder setting and place a probe on each of the pins on the element and if it doesn't buzz or sound then the element is faulty. Make sure you have the electric switched off at all times. Hope this helps
I have an electrolux oven eocl633w. The grill works with the top element but when you select oven, the lights go on, the fan goes but no heat from either element. We thought it might be the automatic timer...
It definitely sounds like the muli-function selector switch. It is probably best to contact the spare parts section of electrolux or the company which owns electrolux and quote the oven model number. You can't always get exactly the same switches as they sometimes discontinue the original.
Feb 14, 2011 | Electrolux Ovens
Hi The fan is this oven dosn't always work! Sometimes if you give it a gentle nudge it will start to spin other times it just wont spin at all & some times it works perfectly! any ideas on how to...
You need to change the fan motor. These motors are not very powerful and wear in the bearing can cause this effect. oiling the bearings is only a tempory fix and you will eventually end up changing the motor.
Jan 22, 2011 | Electrolux EOB5610 Ultrafan Electric...
The grill works, the fan works but the oven doesn't het up
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Sep 08, 2009 | Electrolux EOB5610 Ultrafan Electric...
Oven not heating, and tripping .Aeg Electrolux
check your heating ellement
Mar 24, 2009 | Ovens
Replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Nov 17, 2008 | Electrolux EOB5610 Ultrafan Electric...
Fanforce oven
usually you have a bake and a convection button if you only one button for baking you may not be able to use bake with out the fan good luck
Mar 03, 2008 | Electrolux EOB5610 Ultrafan Electric...
Electrolux EOB5610 Ultrafan Electric Single Oven Logo
638 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
