The resistor 2.2ohms was open when I plug the tv set
  • 12,061 Answers
Must find out WHY, resistor, is OPEN, unusual to spontaneously fail. Must check, power supply..Usually something else, is short circuit, and is drawing too much current over that resistor, causing it to overheat and damage it'self. So you MUST find why this happens. Sometimes, resistors, if overheated too many times will simply fail after a certain amount of time.. Must check that too. Look at other similar resistors see if look the same measure same etc, get overall feel if all good, or all bad or if just that one.
Posted on May 05, 2010
Dead set. Smoke came over the TV.
The smoke is usually came from burnt resistor cause of short circuit or shorted parts inside..
Try to open the back cover of your TV and look at the resistor burnt..and replace it..also try to find shorted parts connected to burnt resistor or behind it..
Oct 22, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No power
Most likely that open 5.6 Ohm resistor is in the power supply, is it a fairly large squarish resistor? If so just replace it and try the set again. I think it's a ballast resistor that has opened up and this can happen with age especially if it was not perfect to begin with.
Try replacing it, I bet it will fix the problem...
Zashiban
May 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Toshiba 36A61 TV Deglaussing Problems
DEGAUSS IS INTERNAL AND ONLY WORKS WHEN THE SET IS FIRST TURNED ON. YOU WILL HAVE TO OPEN THE SET AND EITHER SOLDER THE BURNT CONNECTION OR REPLACE THE THERMISTOR. THE DEGAUSSING COIL GOES AROUND THE OUTSIDE OF THE TUBE(INSIDE THE SET) 2 LEADS AND PLUGS IN CLOSE TO THE AC LINE CORD. IT IS CONNECTED THREW A TEMPERATURE COMPENSATING RESISTOR THREW A RELAY DIRECTLY TO THE A.C. LINE INPUT FOR ABOUT 2 SECONDS WHEN THE SET IS FIRST TURNED ON.
Dec 27, 2009 | Toshiba 36A61 36" TV
My magnavox projection tv has convergence problem.
there are 12 6.8 ohm 1watt resistors in your model. There could be more blown resistors as they often wont show any outward sign of being bad. It could also be the ACS board which is defective if the Resistors are good.
Apr 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sony TV no sound
first open the rear cabinet,if you a tester first test your speaker both side if open ,second check the voltage of the resistor if has a 12 volts going to audioutput.and third if speaker and resistors are good.you to replace the audio output.
Sep 04, 2008 | Sony KV-32FS13 TV
Sharp tv problems
maybe you are a technician you will open your tv set thats why you know that the resistor geting hot. can you figure out witch resistor get hot? The value and wattage. Or tell me the no./color coding.More info.
Apr 10, 2008 | Televison & Video
Adding a audio jack to KV-32S42 sony TV
yes, just tap in at one of the speakers. The jack should have an internal switch so that the internal speaker is hooked up when the headphones are not in. Most TVs are now stereo (even though analog broadcast signals are mono) so may want to get a stereo jack and tie in from both speakers.
Jan 10, 2008 | Sony KV-32S42 32" TV
No Picture Has a bright horizontal line with off white & gray vertical bars
The Problem Philips 27TS54 c101 27B800-7562 White horizontal line in the center of the screen. Color is present in the first half inch of the leftist corner of the horizontal line.
Audio is present and controllable. The green power led from a cold non plugged in state remains solid until CRT goes to ignite. A click is heard then the green power LED blinks.
I found service manual diagram of repair part or parts and install instructions
HTTP://WWW.servicemanuals.net/results.aspx?type=SM&brand=100&model=27ts54
I request any info or tips you might have pertaining to this problem
Thank-you
Sincerely
Gmyers@sbcglobal.net
2/20/2008
P.S. 25”-27” CRT board APT187
Possible Answer Posted by PEE_WEE 4/28/2005
On the CRT circuit board(picture tube), you will find R3340, which is a 10 ohm 1/3w resistor. The location of the resistor is printed on the bottom of the ckt board. It is burned open, replace with a 10 ohm 1/2w resistor. This will solve your problem. The original resistor was sized too small, should have been a 1/2 watt. This resistor is mounted standing up on ends. Mount the replacement resistor the same way. Be careful and don't get the circuit trace too hot and damage the circuit trace. (it's very small) The resistor is located on the crt(cathode ray tube), pcb(printed circuit board) socket. The resistor supplies apx +200v to the collectors of the r, g, b, video driver transistors. If this voltage is low, it causes excess brightness(excess beam current), causing the set to "shut-down". If the shut-down is too quick, you will NOT see the excess brightness, because the picture tube has not warmed-up enough to display anything on the picture tube. To see if the set displays "excess brightness", you will need to turn the set "on" about 5 to 10 times. This will heat the picture tube enough to display "excess brightness", IF that is the PROBLEM. Of course, there are OTHER defects that will cause a tv to shut down. There are built in safety circuits, that will "activate" if excess voltage/current or heat is detected anywhere in the set.
NOTE
My resistors are not numbered the same on my crt board APT187. GSM 02/20/2008
Dec 31, 2007 | Samsung TXK2754 27" TV
HDTV wont turn on
There is a resistor by the high voltage transformer,it has low value and it opens for no reason,he is likely open and does not let the set stay on,if you are familiar with tv service you can replace it and while you are down there check for any over heated areas and resolder them specially the convergence IC.This resistor is located in the back edge of the chassis in the board in the right side and it might be hidden by a plastic casing that covers the high voltage transformer.If you are not too familiar with tv service you should seek the help of a servicer.Let Us know how it goes or if you need more information.
Dec 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Fuse blows when it gets plugged in
No it doesn't sound like a resistor, it sounds like you have a short in power supply, you can look for bad Diodes in bridge rectifier,or solder bridge, or transistor short, start from beginning to end. It is definately a short and most of the time resistors open and this will not cause a blow just a dead set.
Sep 21, 2007 | Emerson EWF2703 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
