Question about Mitsubishi LT-52246 52 in. LCD TV
I have a 3" wide blue streak running vertically down the left side of my screen. What is this?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Does that blue streak appear in all inputs or only in tv channels programs?
  • Anonymous Mar 28, 2014
    Have a blue line vertically coming down middle of the screen. It is approximately 3" wide from top of the screen to bottom.
  • Mitsubishi Master
  • 3,866 Answers
This is comming from your tuner/decoder and the rectification is repair. Your going to need to have a service guy come out and look at it.
1. Tuner/decoder Fault
Thanks, Hope this information helps please do leave positive feedback and ratings for your free answer today!
Posted on May 05, 2010
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Prints 1" wide blue streak from top to bottom of page
If you're holding the paper so the narrow side is up, and the blue streak is vertical, then it's not a bad print head. If the stripe is from side to side with the paper held that way, then possible that the head is bad. The 4530 is an office type printer with large carts that connect to the print heads with hoses. It's possible that a hose has come off and is dumping ink that way, or that the hose is leaking...
Apr 17, 2015 | Epson Pro Wp-4530 All-in-1 Inkjet Wireless...
Vertical blue transparent line plasma
Check for loose or dusty flexible connectors. (Please take care to switch off TV and remove plug from the power outlet and discharge high voltage capacitors before you do anything on the PCB) Apply cleaning oil in connectors wherever possible and remove and reconnect it a few times. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Nakamichi VU50P 50 in. HD-Ready Plasma...
KP-57WV600 Sony Wide Screen tv blue arcs across entire screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem...
Sep 09, 2011 | Televison & Video
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Jan 18, 2009 | Philips Magnavox 42MF521D/37 Television
Black streaks down left side of printouts Epson Aculaser C2600
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Dec 02, 2008 | Office Equipment & Supplies
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Mitsubishi LT-52246 52 in. LCD TV Logo
178 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
