Question about Sharp R-510HW Microwave Oven
I REQUIRE WIRING DIAGRAM FOR A AFTRON AF-W-2420 BC FOR CONNECTIONS AND ALSO TO SEE IF IT MEETS UK REGULATIONS THANKS
  • Sharp Master
  • 12,061 Answers
I Require the salton oven wiring diagram
check with the manufacturing company .
Oct 01, 2016 | Salton Microwave Ovens
Hello, I am replacing the control panel on a Frigidaire Gallery Pro Series stove (it's a combo with gas stovetop and electric convection oven. Model: FCS388WECE Serial NF90100743 I am looking...
With the multipin connector on the right, the wire order is: (across the top, Left to Right): Brown, Green, White, Black, Yellow, Red (double), Blue, Black, Brown w/ White-Red Stripe. There are 2 Black wires which might be a problem... I have a schematic though. If you still need this info, reply to this post and I'll get it to you. Regards, Robert
Sep 13, 2011 | Microwave Ovens
Need wiring diagram for maytag built in oven modelCWE9000
Hello, Here is the wiring diagram. http://c.searspartsdirect.com/lis_png/PLDM/X2900494-00013.png
Hope this helps.. Please Rate Me It Helps Thanks :)
Jun 08, 2011 | Microwave Ovens
I have purchased a spare switch to replace on my Moulinex Masterchef 650 duotronic food processor but have misplaced the wiring diagram showing the five coloured connections to this switch....is there...
Here is another manual link if that one does not work for you.
http://www.manualsonline.com/search.html?q=Moulinex+Masterchef+650+duotronic+food+processor+&submit.x=24&submit.y=17
Apr 08, 2011 | Microwave Ovens
I require ain instruction manual for a delonghi mw865f microwave
just open the link and enter the code given and download the manual
http://www.givemefile.net/manuals/_microwave_ovens/delonghi/file/27939.html
Apr 18, 2010 | DeLonghi Microwave Ovens
Need aftron lcd tv manual
my aftron tv has been locked by mistack.it is showing the locked symbol only.please help me
Dec 19, 2009 | Sharp R-510HW Microwave Oven
I have a GE Profile Microwave Oven model JVM179SK01. The dial button does not work. It is not stripped as someone suggested before. You turn the dial and nothing happens, you push it in to make a selection...
Are you certain there is power to the unit?
You could have a bad latch switch or other component (fuse, other switch, etc.). To determine which it is will require having a volt-ohm meter and knowing how to use it, and the wiring diagram for the appliance, which can usually be found inside the unit somewhere.
Let me know if you want to tackle this, and I will help you as best I can. I do not have a wiring diagram to look at, but will help you to read it.
Dec 11, 2009 | GE JVM1790 Convection / Microwave Oven
Wiring diagram for ballast, fluro & starter
you can also try www.firstlightdirect.com we thought they did everything as well
Dec 10, 2009 | Sharp Microwave Ovens
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Maytag MMV5207A Microwave Oven
Belling Microwave Problem
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Oct 11, 2006 | Belling BIM60 Microwave Oven
Sharp R-510HW Microwave Oven Logo
115 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
