Question about Candy Washing Machines
Candy aquamatic 8T
Can someone help me: my washing machine's door can't open after washing. I was follow all the solving method that the service center gave. For example, wait for 2 min, turn it off to reset. But it doesn't work!
SOURCE: Door won't open
My Zanussi has an outlet filter that is accessible by a little door at the front. It gets clogged if not cleaned for a month or two. Then the machine can't drain and the door won't open. Removing and cleaning the filter should correct the problem. You'll need some sort of container to catch the water that will pour out after you remove the filter.
Posted on Feb 11, 2007
dazmaraz
  • 67 Answers
SOURCE: Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
Posted on Jul 24, 2007
  • 1294 Answers
SOURCE: Candy washing machine fills with water when not on.
Do check your outlet filter, this requires periodic cleaning according to your usage. Refer to your user manual re cleaning filter.
Posted on Oct 07, 2007
  • 3230 Answers
SOURCE: Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
SOURCE: flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
Posted on Jun 03, 2009
How do i fix a door lock on a candy washing machine
go too you tube
type in your candy model and door lock replace etc string get some video help you would be amazed i found over 50 models covered and in great detail
Dec 19, 2014 | Candy Washing Machines
Candy washing machine fitting door rubber
use some paracord look on ebay for a couple of meters
much like the same method to fit a windscreen
some light silicone spray will make it slippy and help
also a hot water soak can be used if its very tight
Sep 27, 2014 | Candy Washing Machines
Who is the dealer of candy washing machine in Sri lanka
you might find something useful by visiting the following website
http://www.beltconveyers.net/crushing-plant/agent-for-candy-washing-maching-in-sri-lanka.html
or this one which seems very similar:
http://www.chinagrindingmill.net/grinding-machine/candy-washing-machine-sri-lanka-agent/
but I am not hopeful. You may find it better to contact a European site such as
http://www.candy-domestic.co.uk/products/?catid=1
and asking your question of them.
24.August.2014
Aug 24, 2014 | Candy Washing Machines
My Candy CNW136 door won't open. My dad suggested trying while it was unplugged in case it was a short but no luck. Please help as I need my washing machine
Try applying gentle but firm pressure to the door part that encorporates the latch pin. (This is the part that closes into the small locking aperture when you close the door. Sometimes these devices stick and all that is required is a helping hand.
Nov 28, 2010 | Candy CNW136 Front Load Washer/Dryer
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
Hi, my candy washing machine is not spining.i open the back to see the belt had fall off ,and not snap.i put it back but it won,t spin. help
not spinning can be related to door lock the door is a saftey switch if not working correctly will not spin but this is for front loader unit also if the pump doesnt drain in the time it should unit will not spin u also could have a failed motor ,motor control etc would need model # to be of any real help most machines have common prob
Apr 29, 2010 | Candy CN146 Front Load Washer
Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Dec 23, 2009 | Candy Washing Machines
Flashing lights on my candy washing machine
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
Washer/dryer stops mid cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Mar 02, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
193 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
