Question about Alpine SWX-1043D Car Subwoofer
No sound i have a 760 watt amp hooked to it and nothing i had another sub hooked up to it and it worked just fine can you help me.
  • 59 Answers
Your positive and negative on the back of the sub is backwards.
Posted on May 07, 2010
Whats the best kind of amp to use with two of these in a box
Walmart sells a 760 watt 2 ch amp.....It works well with these type of subs. Or any amp rated @ 150 watts per channel RMS. Start with the low pass filter on and with it hooked up and playing raise amp level until distortion can be heard through subs...then back off a bit...Your level is now set.
Sep 17, 2010 | Pioneer TS-W1201C Car Speaker
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Hits intemittently
ive had problems kinda like this ... normaly its a crossed or reversed speaker wire check the positive and negitive wire into the speakers "they move sometimes when there is more air moving around the speaker"
second make sure you have the impedence correct "possitive to positive negitive to negitive'
hope this helps
Dec 21, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Jul 13, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Alpine SWX-1043D Car Subwoofer Logo
41 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
