Project Delta Logo
Posted on May 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which language is best for project,java or .net
I want to make a project on the java, so i want to ask u... which is the best option for the project......java or .net...
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
  • Posted on May 05, 2010
Master
Level 3:
Answers
12061
Questions
0
Helped
4007824
Points
36390
JAVA = Old Skool...... Dot Net, is Hip, Now.... Java.. works, sometimes, Dot Net, work, works most times.
2answers
Scala ic5 download software?
(If you don't have it installed, download Java here.) ... This lets you run single-file Scala programs in your browser using Scala.js, including graphical/interactive ...
First, make sure you have the Java 8 JDK installed.
To check, open the terminal and type:
java -version(Make sure you have version 1.8.)
Then, install Scala:
...either by installing an IDE such as IntelliJ, or sbt, Scala's build tool.
or
Best if you prefer a full-featured IDE (recommended for beginners)
DOWNLOAD INTELLIJ
·Getting Started with Scala in IntelliJ ·Building a Scala Project with IntelliJ and sbt
·Testing Scala in IntelliJ with ScalaTest
Best if you are familiar with the command line
DOWNLOAD SBT
·Getting Started with Scala and sbt on the Command Line ·Testing Scala with sbt and ScalaTest on the Command Line Compared to other programming languages, installing Scala is a bit unusual. Scala is unusual because it is usually installed for each of your Scala projects rather than being installed system-wide. Both of the above options manage (via sbt) a specific Scala version per Scala project you create.
But it's also possible to "install" Scala in numerous other ways; e.g., grab Scala binaries and use Scala from the command line or use Scala in your browser!
How to do vb.net framework ??
You need Visual Studio from Microsoft. Inside this visual Rapid Application Development (RAD) tools, you can use c++, c#, or basic language. It is lot of learning to become programmer.
You can find SharpDevelop free programing studio if you want to learn more. With this program, you will need .NET packages on your computer. It is like JAVA from Sun (Oracle). It is copy from Microsoft of JAVA ideas. Like free NetBeans IDE for JAVA development.
Inside studio you will have option for create New project. It can be grafical with graphical designer for draw some button, text input frame ... You will have properties for this objects, and possibility to write programming code. It is lot of learning to do real application. When you write some application you can compile it to exe output.
Visual Basic is only simplest part of this technology. C# (C-sharp) need more learning, and C++ is hardest thing.
1helpful
Is java perfect for projects or I must use VB.Net !please help me
yes java is perfect ...you need not any other language if you have full command on java. okay for more info about programming just mail me at [email protected]
3helpful
Hey plz help me java better ya .net ya oracle??
10 Reasons Why dotNET Is Better Than Java
This post is prompted by a post by SANDIP when he said something like "Java Is Dead" and some people were like attacking him for expressing his view.
I've been a fan of the Java technology for quite some time now. I remember literally copying a Java book when I didn't have the money to buy it.
But one thing I discovered with technology is that it's not always about love but it's more about power.
The bitter truth is when I compare java technology with CLI (popularly known as .NET), I see that Java is less powerfull in many areas.
I'll be using the words CLI and .NET interchangeably refferring to any implementation of the CLI (.NET, Mono or dotGnu)
This are some of my points.
1- In .NET you have a choice of languages to code with (C#,VB.NET, Java,Boo,Python e.t.c), producing the same type of compiled code but in Java one is limited to the java language. One may argue that jython is an alternative, but even the creator of jython who later created it's .NET version called IronPython admitted that .NET is a more powerful technology.
2, NET prgrams run at native speed while java is interpreted which makes java slower.Although java has Just In Time compilation but it stills run slower. With .NET you are not limited to JIT but have the option AOT or ahead of time compilation if you want to eliminate startup delays.
3. Calling native code in java is not a very clean process. You need to generate some stub files which makes the whole process cumbersome and dirty. In .NET you just declare that you are calling a native function from a specified library and just start calling it.
4. .NET languages are richer than Java. They have object oriented feature that are absent in java e.g properties,delegates,generics.
5. Java GUI programs look alien on the host operating system. Even if you use the OS's theme you still notice that the java widgets look out of place.
6. .NET in the form of Mono has brought a whole revolution on the linux desktop in form of great applications like beagle, tomboy, diva, iFolder, banshee e.t.c. This is something that java has failed to do despite the fact that it's been there long
before .NET
7. Many programs that would have been difficult to develop with java have been developed with .NET things like compilers (Mono's C# and VB.NET) 3D game engines (unity game engine) e.t.c
8. The CLI is an open standard maintained by an independent standards organization (E.C.M.A) while java is still governed by SUN microsystems.Even though java has recently been open-sourced, it's future will still be highly influenced by SUN.
9. You can code on the .NET platform using Java but you cannot code on Java platform using any of the .NET languages.
10. Using Mono's IKVM to call java code from .NET or convert java classes to .NET assemblies. This is so efficient that large java programs like the eclipse I.D.E have been runned on .NET.
This is not an exhaustive list but I believe 10 points are enough to send the message.
One more thing, feel free to criticize my views or even flame me.
----YOUR CHIRAG------
2helpful
Suggest me project(mca 6th sem)live provide companies
THE BEST DO'NT FIND THE PROJECT CENTERS IN ANY CITY THIS IS TELL FROM MY EXPERIENCE TRY TO FIND U R EX-SENIORS WHO ARE WORKING IN JAVA OR J2EE BECAUSE THEY CAN PROVIDE THE BEST PROJECT FOR U .IF U R INTERESTED IN ASP.NET I CAN HELP U
email: [email protected]
2helpful
2answers
1helpful
2answers
Spell checker-project
You can look in an open source project like JOrtho at http://sourceforge.net/projects/jortho/ There you can also find the source code of the Java project.
4answers
Working on the live project in JAVA
if you are looking for learning the java language while working on a real time project ,i give you useful resource if you are in chennai it will really worth it for you grab the chance ,they provide a demo seesion over theere you can clarify the further information from there
Java Training in Chennai
Top Project Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Project Video Game Console and Game Expert? Answer questions, earn points and help others
