Question about Pride New Jazzy 600 Power Wheelchair by Mobility
Rascal 600 not charging after sitting for 3 months, batteries are 7 months old
2 Suggested Answers
  • 6 Answers
SOURCE: We purchased a Rascal 300 two months ago that
Also check the fuses.
Posted on Sep 09, 2009
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
My rascal 600 shows fully charge and dead when you sit down on the seat
Hi some came with electric seat :::::: when U sit on the seat it could B shorting out the wiring :: check to c if you're scooter has the electric seat good luck
Mar 09, 2016 | Health & Beauty
I have a rascal and put new batteries in it and it seems they will not charge up what could be the problem?
Hi Chris,,,, Now lets get the silly question out of the way first, have you tried another charger ?
IS it a built in charger ?
Remember a bad charger == Bad batteries...
the lead that goes from the chagrer socket to the batteries via the controller are most likely adding resistance that the charger does not like ...
Regards
Robi
Aug 31, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
On my rascal fold and go 370 it wont move wires are fine battery are a couple months old but it wont move it turns on and the gage just blinks any one help?
Hi , does it flash a code like 7 flashes etc,,,, or bleep a number of times ?
Regards
Rob
www.gewizrepairs.co.uk
Apr 28, 2015 | Health & Beauty
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
My charger on Rascal 600 does not charge. After checking all the common reasons without any luck I remove the charger and could not measure any voltage output. My Dealer sezs the charger won't work without...
Most chargers are 3 pin. Plus and minus charging voltage to the
batteries and a third pin monitors the actual battery voltage, so
that the automatic charger can turn itself off once the batteries
are fully charged. As Brad has mentioned, the connection
from the charger has to be made for the charger to produce
a voltage at those pins. The best way to see if it is charging
is to remove the seat and measure across both batteries..
assuming it's a 24volt system like most. Charging voltage
can be as high as 28volts across the positive of one 12volt
battery (connected in series to the other 12v battery) and the
negative of the other battery. You can monitor the charging
voltage across the batteries with a digital volt meter.
Nov 04, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600 looses its charge after 3 days unless battery is disconected
How do you slip the inner of a wheel to put a new tyer on plrase
Jul 18, 2013 | Invacare Health & Beauty
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
I can not get my Ducati to run it has just been sitting
Hi, Mnskaterdude if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 3 years or older when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
For more information about your issue and valuable free downloads that you will need please visit the websites below.com. Good luck and have a nice day.
http://www.ducatimonster.org/forums/general-monster-forum/291129-2001-m600-repair-custom-paint-job.html
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Ducati Monster 600 Monster 600 Dark Monster 600 City Monster 600 Metallic...
Sep 04, 2011 | 1999 Ducati Monster 600 - Dark - City -...
Been sitting for six months won" start
try your battery first most of the time thats the problem when you turn on your engine you should have lights if you dont then your battery is dead and that is the problem would reccomend you either charge the battery if that dosent work replace it but check first if lights are working a 6 month lie up would deaden your battery best of luck also any battery charger would do for the charge and also on a short term you can jump it from a car battery with the leads just to make sure its the battery also but do not try and charge from the car just check to make sure its the battery by doing this
Mar 16, 2011 | 2003 Honda CBR 600 RR
Pride New Jazzy 600 Power Wheelchair by Mobility Logo
178 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
