Question about ASUS P4P800 SE (890552603657) Motherboard
CMOS battery is fine Light on motherboard is on Nothing happens when you push power button
    Master:
    Sergeant:
  • 460 Answers
May be your SMPS has been faulty.So pls check it with another SMPS.
Posted on May 10, 2010
Vostro 200 will not start up.
check the power supply (smps)
check the CMOS battery
check the motherboard
Apr 13, 2014 | Dell Vostro Computers & Internet
Acer Aspire One D257 - 13450 Will not come on. It takes a full charge, but when you push the power button absolutely nothing happens. Would this be the mother board?
check hard disk and/or ram if connected properly. Clean the motherboard (do it crefully) with soft brush. Check cmos battery voltage, a button cell on motherboard, it should be around 3 volts, if that doesnt fix, you will have to take it to its service centre. Thank you
Mar 27, 2014 | Acer Aspire One PC Notebook
Lenovo thinkpad t400 laptop wont open
try changing the keyboard because switch is on keyboard and use adapter to plug and test
Mar 25, 2014 | Computers & Internet
Hello I have a thinkpad x31 and it won't boot. When I push the power button the lights go on and then they go off except for the power light.Nothing happens after that . I tried booting from other sources....
exacly from the motherboard, i think u can not prepaire because much know electromagnetic to change the chipset so difficult 2 u. u can take to brand for prepair
Jan 16, 2010 | IBM ThinkPad X31 2672 Notebook
My SB light on my ASUS motherboard comes on when i plug in the power cord. when i turn it on, it show nothing.
make sure the ram, cpu, and graphics card is set correctly, otherwise, remove the battery, put the jumpers on clr cmos, then push the power button, while the power is still the in keep do ing it on and of, the remove the power again posh the on button, to make sure all the left over power streams has left the light should die, the put back the battery the replace the jumpers, then the power cord then try again
Oct 07, 2009 | ASUS P4B533-E (P4B533-E/L/1394)...
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
I have a gateway 835gm desk top
there are a number of things that could be wrong here, firstly reset the cmos on the motherboard, if you cannot find the cmos jumper then remove the battery for 10 minutes (make sure the power cord is removed from the back) press the on/off button a couple of times, this will drain any remaining power from the board and properly reset the cmos, while the battery is out remove the memory, clean the contacts and repace, put the battery back in and connect power, if the machine turns on, job done, if not then it could be something far more serious, check the power suppy if could be faulty, the processor may have blown or the motherboard itself may have blown, the only way to check all the components at once is to get a working motherboard which supports your processor type, the same model would be an advantage
Nov 15, 2008 | Gateway 835GM (835GH) PC Desktop
Bki810 motherboard
LED light on motherboard is indication your getting electric , Fan spins also is good indicator but it also does not mean the motherboard works though . If you tested CPU on second motherboard that should have told you the first motherboard has died . ( As long as the CPU can run on both motherboards that is )
Jul 29, 2008 | EliteGroup BKi810 Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
