My wireless system on my laptop is off how can I turn it on? No wireless found in range! Make sure your wireless switch is on how can I put the switch on?
  • 8 more comments
  • Anonymous May 10, 2008
    my light is out. I turned it on & off in rapid motion, then I tried holding button depressed for a few seconds, but nothing worked........Helppppppppp I have compaq presario v2403nr. thank u
  • Anonymous May 16, 2008
    can not find wireless switch on
  • sosoBOLING May 17, 2008
    cannot find wireless switch
  • Kayko Andrieux
    Kayko Andrieux Jul 09, 2008
    I am getting a error code saying that "windows could not finish repairng the problem bc the following action cannot be completed." Disabling the wireless network adaptor. Make sure your network adaptor is properly installed. So when i try to activate my wireless network i hit the FN key and F2 but nothing happens. There is also no signal and no IP address when i go to control panel and hit network connection. HELP!!!!
  • Krishsushi Jul 23, 2008
    I cannto turn on the wireless even if the wireless signal is available. Other computer do connect to wireless but this DELL Inspiration 2200 do not. How to turn on the wireless? I tried to do with Fn and F2 but it do not indicate nothing. Please help
  • lisa1968 Aug 01, 2008
  • Anonymous Feb 01, 2009
    how do i turn on the wireless on my dell latitude d600.i can not connect to the internet.
  • chaeala91 May 05, 2009
    i have a advent 8115 laptop with internal wireless but i do not know how to turn it on
  • Anonymous May 19, 2009
    acer aspire 6530, says cannot connect to wireless network, but it was just working!
  • Stuart
    Stuart May 11, 2010
    Which laptop is it?, make and model.
    Genius:
  • 1,027 Answers
Some laptops have a switch in front next to the wireless light or on the side.
Some laptops use an F key (my toshiba is F8) so to turn on the wireless I would have to turn the switch on in front and then "toggle" the Wireless on by pressing the FN and the F8 keys.
Posted on Mar 26, 2008
I have a compaq presario cq43 the orange light will not turn off is there another way i can turn that light off im unable to use the wireless i have to keep the interne cord plugged in
Posted on Sep 04, 2012
    New Friend:
Above the NumLock, there is a button with an icon of a satellite dish on it. Looks more like a light than a button, but press it anyway, it will start blinking when wireless is on.
Posted on Aug 30, 2010
Acer is notoriously bad. The 6530 has a problem connecting to wireless, even when "Wireless Lan" is enabled. You have to turn wireless on and ff about 15 times. Eventually it will find your network
Posted on Dec 29, 2009
    New Friend:
I have a hp pavilon laptop and i cant turn on the wireless button or find out how to.
Posted on Jan 04, 2010
I have an hp Presario model num cq61305sa were is the on button for wireless conetion please
Posted on Jan 29, 2014
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Well. In the list of F's t the top e.g. F12. Find some key that looks, a dot with three circular lines. Mine is F12. Once You found that key click Fn - F12 Or your key. Fn is next the the Ctrl Button.
Posted on Jan 08, 2013
2 Suggested Answers
SOURCE:
  • 438 Answers
SOURCE: My wireless system on my
It seems that the drivers for wifi have got corrupted. Please uninstall the wifi from control panel-system-hw-device manager. And the after a reboot go to same place and scan for new hw under Actions. The wifi will be reinstalled and drivers will be reloaded.
Posted on May 29, 2011
Wireless card Not found
Where is you get that message or indication from?
Is the wireless listed as a device in the device manager?
Did you turn the wireless switch on?
Download and reinstall your wireless drivers.
Get online and got to www.google.com In the google search box type: "Toshiba Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Network drivers.
Make sure the wireless switch is turned on.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Still not working?
If you still have problems then turn the laptop off, remove the power cord, remove the battery, then remove the cover that houses the wireless card on the bottom of the laptop. Remove the antennas (2 cables) from the wireless card (remember how they go so you can put them back later), then remove the wireless card from the slot ( it might be secured by one or two screws you have to remove). After about 30 seconds put it all back together and reboot. Sometimes reseating the wireless card will make it work.
Jun 05, 2012 | Toshiba Computers & Internet
Wireless network connection ,says that no wireless network were found in range
Look on your function keys there could be a radio tower symbol. If you have one press and hold the FN button ( left side on the bottom of keyboard ) and then press the button with the tower on it that should turn on / off your wireless. you may also have a switch on the sides or front which maybe turned off also check for that.
Apr 25, 2012 | HP Compaq nc6000 Notebook
My wireless system on my laptop is off how can i turn it on?No wireless found in range!Make sure your wireless switch is on how can i put the the internet
May 29, 2011 | Computers & Internet
I have belkin connect n150 and i have two laptops my one laptop is connect to wireless but the one laptop cant access to wireless it says no wireless network were found in range..
If your message is like this " no wireless network found in range make sure wireless on the computer is On". All you need to do is look for the wireless switch usually located on the side or the back of your laptop. Sometimes its near the F keys or start button. You may check your laptop manual to see where to locate the wireless switch , or you can check the laptop manufacturers website usually they gave information on where to locate or enable the wireless feature of laptop.
KA
Mar 30, 2011 | Belkin Basic Wireless Router
Can't get connected to wireless mst laptop
Here's the checklist:
  1. Make sure the wireless transceiver is turned on. Almost all laptops have a switch that lets you turn it off when not in use to conserve battery energy. The switch is usually on the front edge of the computer.
  2. Check the router protocols (for steps 2, 3, and 4, connect to the router's web page using a computer connected to the router with a network cable). If, for example, the router is using 802.11n only, and your laptop has an older wireless card (802.11b or 802.11g), they won't talk to each other. In that case, you would want to set the router to mixed protocol mode.
  3. Check the router security settings, and make sure your laptop's settings match. They should be using the same encryption (TKIP or AES), authentication type (WEP, WPA, WPA2 - WPA2 is preferred) and wireless security key/password. The laptop computer's settings are found by right-clicking the Wireless Network icon in the System Tray and selecting Properties.
  4. If the router has a limited client list, make sure the MAC address for your wireless card is properly entered on the list. If the wireless card was factory installed, the MAC address should be on a sticker on the bottom of the computer.
  5. Consider range limiting factors. If the router or laptop is located too near ductwork, metal appliances or even metal furniture framing, this could create blind spots in the broadcast patterns. Sometimes moving a few inches can make a significant difference. You can check this by right-clicking the wireless network icon in the System Tray and selecting View Available Wireless Networks. A list of networks in the neighborhood (including yours) should show the relative signal strength of each router at your location. Note that the strength of weaker signals is often highly variable - it may be different each time you refresh the view.
I think I covered everything other than hardware problems. Sometimes you can get everything matched, but the router and laptop still won't talk until you shutdown and restart both (turn the router back on first). I had a Windows Vista unit with this issue when Vista first came out - after that it never again had a connection problem with that router as far as I know.
Feb 02, 2011 | MSI Computers & Internet
IBM Thinkpad laptop Wireless connection not working laptop is asking to switch on wireless switch- "Where is it?"
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
Dec 20, 2010 | Computers & Internet
Suiddenly lost my wireless connection. (Dell Inspiration E1705)
make sure the wifi enabled and wifi light is on. to enable it press "Fn" and "F2"
Feb 19, 2010 | Dell Inspiron E1705 Notebook
My laptop will not connect to wireless internet anymore. Connection screen shows no wireless networks found in range. Normally there are ten or twelve in range
  1. Make sure that the wifi button is on in your compuiter.
  2. Try to look for a sliding switch or a button at the front or side panels of your laptop.
Hope this helps!
Nov 10, 2008 | Gateway Computers & Internet
How to set up Wireless connections
You have to have the "Other Half" so to speak... wat ya missing is someone else to connect to... Usually one ALSO has a WiFi Router OR connect to an "Access Point" both of these provide a WiFi Signal that can be accessed by your Wifi. blow are a couple of helpful links. To help you set up a home network. www.techtree.com/India/Guides/ Setting_Up_a_Wi-Fi_Home/551-74315-560.html www.microsoft.com/.../resources/technology/broadband_mobility/ hooking_up_with_wifi_6_things_to_know.mspx
Sep 05, 2007 | Computers & Internet
Computers & Internet Logo
10,659 people viewed this question
Ekse
Alun Cox
