Question about EliteGroup K7SOM Motherboard
My computer has no displayed on the monitor but has a power,it's attached to the built-in video card of mother board the model of my mother board is "K7MOS+7.5C" what should i do???...
  • wongcarlklev May 05, 2010
    i cleaned already but didnt solve the problem,still theres no vga and no beeps at the starting when i turn on the power of CPU.
  • 979 Answers
Hello Wongcarlkley, hi, looks like you have memory module problem, need to clean module contacts using pencil eraser, try this fix first and see if it will solve your problem.
Posted on May 05, 2010
  • Jerry Umali May 05, 2010
    to add,
    remove the memory modules, to remove this, unlock the two locking lever on both side of the module. using eraser, clean wipe the gold plated contacts, and replace back again on motherboard. clean all modules. then replace back all modules, or test one by one.
  • Jerry Umali May 07, 2010
    If the memory module is not the problem, have those memory modules check on another computer. just to confirm. then we go to connection, make sure that the 4 pin 12V molex connector is connected, the black yellow black yellow one.if still no power, visual check the motherboard for rat pupu, (rat waste) on your board and cards. does your casing has small holes where small rats could enter?
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Blank display on the Monitor when connected to main system
if u feel the problem with you display cable then try to replace that
May 12, 2010 | Philips 107E56 17" CRT Monitor
After display goes black monitor green power light remains ON. Power can be turned of and the display again stays on approximately 5 seconds. Replacing capacitors in power supply did not correct the...
The problem can be the lamps are bad, the only way to tell is to remove the lamps, look for poor soldering works where the wires are attached to the lamps, bad lamps will have very dark color at the end of the lamps, just like bad fluorescent lamp you see when it is worn out, anoher sign of bad lamp is pinkish glow when lamp si first turn on. The transistors and caps are good in the inverter section?
Jan 02, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
No display at start
If you provide some background information, I can answer your question better and faster.
When did this first occur?
Can you think of anything that happened just before this happened that might have caused it?
What trouble shooting steps have you already taken?
Do you hear any beeps?
If you unplug the monitor, does it display anything at all that indicates it is working but not receiving video from the computer?
If there is no indication of display, try another monitor or try the monitor on another computer.
If the monitor is good, next check out the computer.
First steps to take are to simplify the system to the bare necessities of being able to display an image.
Unplug the power cable and then disconnect every single bit of equipment attached to the computer except the monitor.
Reconnect power cable and retry rebooting.
If still no display, unplug power cable and open the case of the computer. You can have a knowledgeable friend do this if you feel uncomfortable opening the computer.
Once open, remove any expansion cards other than the video card. Disconnect all the power and data cables from every drive in the system (hard drive, CD or DVD, floppy drive, etc.).
Reconnect power and try booting to see if you have a display.
Let me know if you need further help.
Honest1abe
Dec 29, 2008 | Intel D101GGC Motherboard
Similar problem ... Help!
NO dont disregard the pwr supply,I would use the hot/cold fault finding aids first to isolate the problem aera. regards CHOOK.
Apr 17, 2007 | CTX S762A 17" LCD Monitor
Digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Jun 03, 2006 | LG 1720B 17" LCD Monitor
EliteGroup K7SOM Motherboard Logo
107 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
