Question about Dishwashers
Neff dishwasher our dishwasher is six years old and have had no problems till now . there is power to it but when you push the on button the impeller starts up even when the door is open , and it wont go through the cycle , its asif there is no water going in and it is not draining away i have checked and cleaned the filters but nothing, then pulled it out from undre the sink and it started working . i put it back , it went through the cycle then the next day it would'nt work again . do i need a new pump ? any ideas ?
  • 25 Answers
You have a faulty door switch. It can be replaced and may be available at youre local appliance parts dealer.
Posted on Mar 26, 2008
Neff dishwasher - bottom tray not cleaning - rotary arm not turning
If your dishwasher is 10 years old and you are facing a significant repair cost, it may be time to consider replacement.
Jan 01, 2014 | Neff Dishwashers
I have a Neff Dishwasher S5443X2 and the dishwasher tablets are not dissolving. The tablet door is open when the machine finishes but most of the tablet remains. We tried using detergent but still the same...
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jun 27, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher will not turn on, power check done, please help
this looks like a power supply problem if you are sure you are getting power right up to appliance it can only be a electronic failure pcb open circuit etc anything else and the lights would still illuminate.
Jul 25, 2009 | Neff 24 in. S5444X1GB Built-in Dishwasher
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff built in dishwasher
these arms rotate only by water jetting out of angled jets at the end. it is likely that these jets are blocked - not always obvious
Nov 10, 2008 | Neff 24 in. S5456 Built-in Dishwasher
NEFF DISHWASHER S5443 STUCK IN TEST MODE
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
Nov 05, 2008 | Neff 24 in. S5456 Built-in Dishwasher
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Oct 09, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher stuck on wash cycle
sounds like the relay on the control/power module has jammed there should be a reset position on the board it usually involves pushing two selection buttons at the same time try resetting it
Jul 03, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Neff built in dishwasher model no: S4453N0GB/07 When you switch the dishwasher on all the relevent lights swich on, indicating the dishwasher is ready to use. but when you switch the start button it clicks...
We fixed the problem at home. The Start button had a loose connection.unscrewed the panel and pushed all the wires in and were able to restart the dishwasher.
Feb 29, 2008 | Neff 24 in. S4456 Built-in Dishwasher
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
May 26, 2007 | Neff 24 in. S5555X0GB Built-in Dishwasher
Dishwashers Logo
205 people viewed this question
Top Dishwashers Experts
