Question about Sharp 19L-M100 TV
No Display after servicing a tv for vertical fault (closing in) by changing four filters,the display refuses to show, although the remote works the tv good enough, it was recognized that no channel display was evident nor the volume display or menu display on this tv, can I have some assistance on this problem thank you in advance
  • 129 Answers
Good day.
Check on the resistors near the flyback for possible change value(120k).
also, check on the losse terminals of the chroma system
chris
Posted on Mar 28, 2008
SOURCE:
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
TV displays snowy vertical lines. AV reset does not correct the issue.
Type in the brand name only to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 11, 2015 | Televison & Video
After turning screen ix initially blank although backlight is on. Gradually vertical stripes appear of varying width and colour. Eventually lines change to horizontal bars howing sections of the correct...
Your display is faulty. Check out ebay for a replacement. Changing the display is straight forward. If you get your display we can instruct you on replacing it.
Hope that helps.
Nov 09, 2010 | HP Compaq nx6325 Notebook
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Exact same problem on 47" Regza: multicolored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 23, 2017 | Toshiba REGZA 47HL167 TV
'03' is displaying on my screen
First try, using the remote, pushing the display button until the display is turned off (three to four depressions on the remote display botton. Second try, unplugging the tv for at least 2 minutes then plug the tv back in. This should reset the tv if you have lost the original remote with the display bottton.
Dec 30, 2008 | JVC AV-36260 TV
No volume and channel display
In this situation as I don't know what adjustment item has been changed, go to service mode and press 5 and 0 on remote. This will reset all adjustments data on factory default. press mute and zero to write on memory. I want to inform you that after above procedure, you will have to adjust Horizontal, Vertical picture size and pin amp adjustments to get normal picture.
Good luck.
Sep 10, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Jul 27, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
What is the focusing screen display?
There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Sharp 19L-M100 TV Logo
88 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
