Question about Nokia N70 Cellular Phone
My mobile n70 not stand on charge above 3 to 4 hours
  • Nokia Master
  • 4,737 Answers
This problem is usually caused by battery but on rare conditions the charger as well. First of all, try with another battery (your friends' or..) and keep it charging for 1 hour and see the result, Second try with another charger. If the problem still persists then there might be problem with charging ic which you can't fix it if you are not a mobile technician. Give it a try and good luck..
Posted on May 05, 2010
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Nokia N70 no signal problem
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 10, 2013 | Nokia N70 Cellular Phone
Softwire problem. my N70 music edition White Screen
my nokia n70 mobile phone screan saver not sopourt
May 17, 2009 | Nokia N70 Cellular Phone
N70
mobileCAM>
http://www.mobiles24.com/downloads/d/MdWkKUscWj
J2ME CAM>
http://www.mobiles24.com/downloads/d/21s2cAyams
Q-Spy CAM>
http://www.mobiles24.com/downloads/d/VZGKa4Rqfw
All above link are copyright of Mobiles24.com
DISCLAIMER:your mobile plan/charges for GPRS or internet Charges cannot be claim from Me, or mobiles24.com
to allow your opposite site to see you you need to give your opposite site your phone IP address, which will be shown when you start the application. if your phones shows: 123.456.7.8
Give this list of number to your opposite and ask them to key it into their internet explorer.
type at the address bar:"http://123.456.7.8/"(without quotes)
Mar 19, 2009 | Nokia N70 Cellular Phone
My nokia n70 wont turn on
take the phone to a mobile service center and have them fix it for you
Nov 21, 2008 | Motorola Mobility RAZR V3
N70 Battery Issue
Even when you run the mobile in offline mode you might use it for listening to songs or any other applications..So please check if the battery life stands for around two days to around when you choose the network selection..If not then better take you moobile to any Nokia service centre..!..
Aug 11, 2008 | Nokia N70 Cellular Phone
Key pad mafuntioning
Hi, there is your mobile dialing fault there may be inner keypad is demages. so if you can chang it, pl chang and check it. For ur second problem is phone not go on when fully discharges, at this time you have to put your mobile under charging for three or four hour, dont worry when u put mobile in charging mobile will not shows charging but there is a charging is on in mobile after one hour mobile will shows charging automatically. ok. test this and pl.reply earliest.
Oct 17, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
