Question about Cobra 19 Ultra II CB Radio
How do you wire a PA speaker to a Cobra 19 CB radio? I know this is broad yet nothing has worked including using a 6' 3.5mm mono audio cable with tinned ends and connecting the pa speakers wires with the tinned ends using connecters. Could something be wrong with the CB radio it was bought from walmart yet when pulled out of the box the wrapping was in the bottom of the box not on the CB or mic. The speaker is brand new. Any help would be appreciated.
  • 12,061 Answers
  1. www.cbmonitor.cz/...manualy/Cobra/Cobra%2019%20Ultra%20III%20manual.pdf
    pdf.textfiles.com/manuals/.../Cobra_19%20Ultra-II%20CB%20Tranciever_Manual.pdf -
    User manual. www.cbtricks.com/radios/cobra/7_ultra/graphics/cobra_7ultra_sm.pdf
    usually, you connect up the PA,ans switch, it on and talk, it will not go unless selected. use the maual to help.
Posted on May 05, 2010
Cobra 25 soundtracker with nightwatch
plug the external speaker into your PA jack and select the PA switch. If PA works then the audio chip is good. The cobra 29 must have a mic plugged in to get receive audio, You may have a broken wire at the mic connector.
Jun 19, 2014 | Cobra 29 LTD CB Radio
Pa
per fcc rules (laws)? you cannot put an amp on a cb. max output 4 amps. you should be able to put a pa speaker using the pa output jack. take your radio back for warranty.
May 19, 2013 | Cobra 19 DX IV CB Radio
Wiring a pa
right next to the external out put of the external speaker is a similer plug .It says PA. set the plug in the outlet and push on it to make sure it goes in and now you have PA.
Aug 03, 2012 | Cobra 19 Ultra II CB Radio
Cobra 19 DX IV stuck on busy no matter what i turn or press. even pressing PA doesnt swith it to PA.
check the mics wiring if the mic is not right on some cbs the sound goes off
Jun 18, 2012 | Cobra 19 DX IV CB Radio
I got a cobra 21 from my grandparents house when we were cleaning it out and i am trying to hook up my pa to it but it wont work i checked all my wireing and i am getting power to the radio but the pa is...
If the audio chip is bad in radio you will hear no audio on cb either.
Are you sure it is in right port?
CB/PA switch on PA
Mic bad there is and audio wire the can be broken in mic this will still let needle move on meter.
Hope this helps
Jul 26, 2011 | Cobra 21 LTDST 40-Channels Base CB Radio
Installing a cb radio into car cd player. but I
Too much Feedback will result from running P.A. audio to the CD Player speakers.
Jan 29, 2010 | Cobra 19 DX IV CB Radio
PA squalls when mike pushed
Try running a temporary wire for grounding.
Tom
Jun 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Installed a cobra CB ultra III on a motorcycle
The external speaker jack was not designed for a head set. It has too much power it over loads head set. You need to solder a resistor in line with the negative wire. You will have to experiment to see which value gets the audio just right for the head set you are using.
Jun 13, 2009 | Cobra 19 Ultra II CB Radio
CB radio PA speaker
Freddy, hello. The first thought that comes to mind with your problem is that if the 29 is an older model, the audio circuit or audio chip could be tired. If your talking about the receive volume being low thru the ext. speaker, then there is a rx. wire inside the mic cord. When it breaks, it cuts the volume in about half. The rx. wire is on pin # 4. Maybe your using the wrong ohm value speaker. You need 4 or 8 ohm. If you are refering to the outgoing modulation being real low, then the radio mod. has just been turned down to 50-60%. That's about all I've got for now, not being able to actuallly see the radio,,, Have a good day, and let me know how it goes,, Mechanic
Oct 22, 2008 | Radio Communications
PA speaker quiet
I think this is a double post,, am I right Freddy??? Mechanic
Oct 22, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Radio Communications Logo
740 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
