I need the power cord and the other two cords for model#1701ap.its a monitor .the monitor has 3 cables that hook to the back of it Ineed all threre
  • 11,800 Answers
All cables can be fount at any IT shop or site. BTW you need only 2: one for power - like this one
http://www.ciao.co.uk/Belkin_Components_Power_cable_Power_3_pole__5369096 -
and only one for data - like one of these
VGA  http://www.amazon.co.uk/dp/B0000B1K4E/ref=asc_df_B0000B1K4E642217?smid=A1AUCPBF2P18HS&tag=ciaouk-ce-mp-21&linkCode=asn&creative=7974&creativeASIN=B0000B1K4E
DVI    http://www.corporatecoms.com/catalog/product/view/id/9231/s/belkin-cable-3m-proseries-dvi-dvi/
Posted on May 05, 2010
Model 702 mag monitor-is it compatible with a dell pc
which dell model computer are you referring to
most monitors will work you will need to connect the monitor with a vga lead and a power lead
hope this helps
Oct 29, 2011 | Computers & Internet
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
Hook up to the CPU
Two cables are needed, Power and Data signal (VGA). Most monitors take the same type of power cord as computer power supplies. (Some computers will allow you to plug in a slightly modified cable that will power the monitor off the computer's power supply. This cord has similar ends on both sides (with the prongs inside a rubber housing). The only issue with this is it makes the power supply work harder and thus can fail sooner.) Most computer supply shops (online and brick-and-mortar) will have the power cables, if you don't have extra cables hanging around.
I hope this helps.
Mar 20, 2010 | Gateway 7004618 (Black) 17 in. Flat Panel...
Moved computer to new location. rehooked all. monitor wont start
Without seeing your make or model on you monitor it is difficult to give you any advice.
But with that said.. If your monitor is a flat screen there is a power cord that plugs into the wall the cord is connected to a small box (power converter) out of the box is a small connector that goes into your monitor. It is small and you may have to turn you Monitor over to see exactly where it connects.
Your computer will work whether or not you have Internet service.
Sep 08, 2009 | Star Logic 17" LCD Monitor
I need a cord I need for an observation cam from magnavox
Strange, I have the opposite problem, I have the cord and camera, but no monitor. I found the following fix below to make this camera hook up to any tv or monitor, but it's greek to me. It may help you though! Or, if you can translate these instructions for me to hook up mine, I'l happily GIVE you my cord!
"The DC power was sent up the coax and the video is AC coupled and sent back down. If you open the
camera and trace the wire from the center pin of the UHF connector, it will lead to an inductor
and a large value capacitor. The video is coupled through the capacitor, which blocked the DC
power from the video output amp. The inductor (coil) blocks the video from getting back into the
power section.
Cut the inductor loose from the center wire of the connector. Put well filtered +12 VDC at 500
mA (1/2 amp) or greater into the inductor at this point while running a video cable from the jack
to a video monitor or to the video input of your home VCR. Then you can see the video on your TV.
Power return is to the ground of the connector or any other convenient grounding node.
Jan 28, 2009 | Philips Magnavox 27MS343S 27" TV
Monitor
Monitors need power cords to function, & there is nowhere near enough power in the data cable to power the monitor. So, it sounds like the power cable got pulled out somehow and is now lying on the floor. The power cable will be a small plug like you have on a radio or other similar devices instead of the standard sized plug that older monitors have. Once you plug the power cord back in, it should be fine.
Jul 01, 2008 | Microtek C783GM 17" Flat Panel LCD Monitor
Power cord
you can purchase it either from the manufacture of the monitor
or
ebay(www.ebay.com) or best buy
its called the power cable
just tell the perdson you are purchasing it from that you need a monitor power cable.
Jun 10, 2008 | Balance CM2019 19" LCD Monitor
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
