Question about Zenith B27A11Z 27" TV
Picture has a purple colors, mainly where white may be.
  • Zenith Master
  • 12,061 Answers
Http://www.eserviceinfo.com/index.php?what=search2&searchstring=ZENITH
OK download the service manual for your unit, inside are troubleshooting and repair procedures, it's all in there..
Posted on May 05, 2010
My Viore plasma has a great picture but no color, the menu pops up in color though.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 24, 2016 | Viore Televison & Video
Too much purple in sony bravia
Try to examine the screen with the color turned off---is it a uniform color other than gray or black and white?
A photo posted somewhere with a link showing what it looks like might be helpful.
May 15, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Proscan lcd picture show purple
Green color output section has the fault. Check that section.
Mar 22, 2012 | Televison & Video
Model ds31590 screen has a reddish purple tint whether it s on tv or video i have already tried to change all picture settings and set back to factory settings still has same problem,here is an example...
Chances are real good that your picture is showing its age. There are three color beams in the neck of the picture tube. When these electrodes are operating correctly the will produce an arc, that will produce the proper voltage for color correction. Much like the spark plugs in your car. When you have a fouled spark plug, you replace it. In the case of a TV, replacing the tube is the best way to correct the picture you are looking for. It would be to costly to do this of course. Another option is to rejuvenate the picture tube. Once again, rejuvenating the picture is last resort. Customers must be warned that rejuvenating may work or even in some cases destroy the picture tube. I want to remind you as well, the symptoms you describe will over work the main board as well. This TV is not feasible for repair. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sanyo DS31590 31" TV
I dont know what color wires are for what, i had my head unit stolen and now im not sure what wires go to the new kenwood head unit
The three main wires you need to worry about are the
Ground (Black) Battery + (Red) Constant + (Orange)
As far as the speaker wires goes you are going to have to trial and error them. They are usually color coded so for instance one wire is purple with a white stripe there would be a purple wire with a black stripe that would correspond with it. Every vehicle is different in how it is wired. I know installing a stereo looks intimidating but just split up the wires and you will see it is quite simple. Do a professional job and use crimp connectors, going the electrical tape route is never worth the time it saves.
Nov 24, 2010 | Car Audio & Video
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
Apr 07, 2010 | Car Audio & Video
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I am trying to connect my portable DVD player to the TV in my hote; room. On the back of the TV there are red and white connection for the audio but not a yellow for the video. I have audio and i have...
You're connecting to an HD connection that's why you are seeing the purple and green.
You should have 3 composite inputs, ie. yellow, white, and green on the back, and on the side in addition to the HD ones you are currently plugged into.
Jan 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Zenith B27A11Z 27" TV Logo
89 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
