Question about Nokia E55 Smartphone
Every thime when i install a program it says file is corrupted, but i install the sime program in an other phone it doesnt show any such warning, it works in another phone, what is the reason for this?
  • Nokia Master
  • 4,737 Answers
What kind of program? It's seems you've installed programs which is not supported by your mobile. You can check the supported programs from the link below http://www.mobileheart.com/cell-phone-softwares/1709-Nokia-E55-Software.aspx good luck..
Posted on May 05, 2010
Ufoune sime is no my use at this sime is block
i think your phone is locked. you need to unlock your phone. you can try unlocking your phone through codes. its the safe way to unlock your phone. because when you unlock your phone through software or hardware there are possibilities for data getting corrupted or lost. but there is no such possibilities when you unlock through codes. thats y i prefer this method to unlock my phone. i got the codes from this site Onlinegsmunlock.com to unlock my phone.
Sep 20, 2011 | Motorola Mobility V551
3110c themes unable to open and show corrupted
Since, there is no answer from our expert let me give you a hint.Actually we could not restore the corrupted files without flashing the phone.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 07, 2011 | Nokia 3110 Cellular Phone
I cant unistal all application thats I have instal on my nokia, and cant instal any of application too. It always said remove program failed and file corrupt everytime i want to instal new application
If you failed install or uninstall from the phone, you can do it via PC Suite, its more powerful.
If you get file corrupt notification, then your installation file is broken or there are disturbance during installation process.
Leave them and download the new installation file, try to install again.
If you feel this helpful, RATE please !
Jan 20, 2011 | Nokia E63 Cell Phone
I dowload files in my nokia n95 its says ''file corrupted'' how can i fix just it? please answer me
Usually if files are corrupted they will not get installed. In case they do, try removing them like this:
1.)
MENU
APPLICATIONS
APPLICATIONS MGR
scrowl down and look for the program you have installed, go to
OPTIONS
Select REMOVE
If this procedure did not work and it is not a program what you installed but maybe a regular file, do this
2.)
MENU
TOOLS
FILE MGR
choose between your phone files or memory card files selecting with the right or left arrows bottons of your phone and then look for the files you want to remove
OPTIONS
DELETE
Nov 21, 2010 | Nokia N95 Smartphone
When i start my hp scanner then 1 warning show. the warning is " where is the file of hpf2vw10.dat " so what can i do ? pl. help me.
Uninstall the scanner drivers and install them again from the cd given or downloaded from online.
The dat file is missing due to corruption or a bad install.
Dont worry. This should solve the problem. Cheers!
Aug 16, 2010 | Computers & Internet
Themes showing as corrupt file while installation
theeme file had got virus... so u format ur mobile.... format code. *#7370#
ur mobile wil be formated. but the default softwares wil not be deleted... thank u
May 06, 2009 | Nokia N70 Cellular Phone
Error 0x80040702 while installing corel draw 11
http://www.download.com/1770-20_4-0.html?searchtype=downloads&tg=dl-20&query=registry&tag=srch
Download one of these programs and it will check for files that have been corrupted that is not allowing you to download your file
Feb 17, 2009 | Corel IGrafx Process Central 2005 - 2...
Logitech image studio 7.0.0 SE
corrupted file or bad install completly remove drivers and software from comp even in the programs file then do a complete install and do an upgrade in your software
May 23, 2008 | Logitech Webcam
Nokia E55 Smartphone Logo
48 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
