Question about LG WM2688HWM TROMM SteamWasher
Jet spray nozzle not spraying water.
On all cycle, I observed the entire cycle and no water sprayed. No water coming out of the holes rather water slowly coming out of the drum holes during rinse cycle. The first tech that service the unit has no knowledge of this new model. Second tech with an impressive lap top computer, said it is "normal"(???) that there is no noticeable water (no water at all) coming out of the jet spray. I don't believe it or else that jet spray unit is a useless part of the washer.
Could it be that the water tube connecting the jet spray (if any) was disconnected?
    New Friend:
IHaveSameProblem. I Think They Are Non Operational.No Way Water Can ShootOut Of Those.
Posted on Oct 08, 2013
    New Friend:
I have same problem
Posted on Feb 05, 2013
If no water is coming out at all, it might be that the inlet filter is clogged or the Est. time shows the code IE. To clean out the inlet filters, unplug the washer, turn off the water, open the valves, take a filter cap thing and try rinsing it out. To put it back to operational use, reverse the steps above.
Posted on Mar 30, 2008
  • Heidi Fleiss Feb 05, 2013
    If the filters inlet filters are clean & same problem what could it be ?
SOURCE:
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
Water coming in dishes not getting cleaned enough.possibly not coming out of the sprayer and spin blade
Look inside the spin blade and see if there is food or paper inside of the spin blade exit holes blocking it from spraying and spinning. Also if the spin blade is not aligned with nozzle which sprays water into the blade it will not work. I have had both happen several times. Sometimes dishes or pans pushing against the spray nozzle will also miss align the spray jet so the water does not get into the spin blade. I have also had the spin blade be completely worn and would not spin creating the same problem you've had so I had to replace it. Hope this helps.
Oct 04, 2013 | Maytag Dishwasher
The rear wiper works but water jet doesnt ,rover 96n reg ,any ideas.
Pull the hose off the nozzle and see if it is a clogged spray head.
Jul 13, 2012 | Cars & Trucks
Soap gets clotted is soap dispenser. Dishes greasy and dirty after cycle.
Hi, the soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the machine started working and cleaning like it was new.
Jun 26, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
Water spray not working
I got a thin needle and gently made a hole through the centre of the nozzle - where the water would usually come out. That cleaned the scum build up out of it and it's working fine again. My nozzle does seem to look like its going into the iron but perhaps it's to get the correct angle of spray onto the clothes.
Feb 13, 2010 | Sunbeam Irons
Briggs and Stratton pressure washer will not spray water. The engine is fine but water does not flow.
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Jan 30, 2010 | Briggs & Stratton Pressure Washer...
Water nozzle sprays only with thin jet of water-water will not fan out.
CLR
BUY SOME CLEAN OUT THE HEAD REINSTALL HEAD USE AS PREFERED
also check you are ajusting the head right
failing that buy a new head
Jul 27, 2009 | Karcher Garden
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Washing Machines Logo
1,069 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
