Question about Bosch Nexxt 300 Series WFMC2201UC
How do you open pump door? - Bosch Nexxt 300 Series WFMC2201UC
    Problem Solver:
  • 10 Answers
The access panel on the lower front of the washer can be opened by prying up the lower side of it (near the small hole, I'm guessing repair guys have a special tool to do it), and at the same time twist the whole thing clockwise.
Do the reverse to put it back on.
Posted on May 11, 2010
Washer won't work and door is locked shut with clothes inside. Can I get the door open manually?
turn off . turn off power point. Wait 3 minutes then turn on power point. Try blowing on drain pipe then turn dial to spin cycle .
See if water pump is engaged during spin cycle.
Don't know if you can manually open the door
Had a similar problem and found the water pump was not pumping the water out and spin cycle was failing to complete.
Check filter of front loader as well .
Mar 19, 2016 | Washing Machines
What does the code PO mean?
Hi, PO means Pump Out (lid opened).
Po flashes when drain pump begins pumping out water from tub upon activation by the door lid having been left open for more than 10 minutes.Close door lid to stop drain pump.
Oct 04, 2010 | Whirlpool WTW6400SW Top Load Washer
Whirlpool frontload washing machine door will not open after the
if there is still water in the washer you can use a wet dry shop vac and attach it to the end of the drain hose.Once all the water is removed from the washer you should be able to open the door.
then you need to check the drain pump for anything that may be obstructing the pump. make sure to check the hose that leads from the bottom of the tub to the drain pump.
Jun 21, 2010 | Washing Machines
Front door does not open
Must be something in the pump. Take the bottom panel off and open the pump cleanout. Tech sheet for trouble shooting is just behind the motor control unit(white boX) to the left there.be0ff1b.jpgdb21830.jpg132e75c.jpg
May 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The door do not open when the wash is over and it say somthing about the pumpe
It is a safety feature Door will not open if water is in machine Drop drain hose to floor level and it should drain and allow opening of the door, Next check pump
Sep 27, 2009 | Washing Machines
Drivers door sensor not working. Electric fuel pump is not activated when drivers door is opened. Warning for lights left on when exiting car not operational
It's the switch on the door frame that detects when your door is open. VW's are notorious for this problem. It either needs to be cleaned or replaced. Definitely try cleaning it first. It might be stuck in the "door closed" position.
Jul 20, 2009 | Volkswagen Golf Cars & Trucks
Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
All four doors will not open. Door locks accuate with key in drivers door, trunk is only one that actually unlocks and can be opened, all other "sound" like they are unlocking but will not open. Can lock...
hello,good day,seems your have a bad contact on driver and passenger switch door actuator,maybe loose contact or mechanical defect,which not sending a signal to your central locking pump,try to remove your rear seat,look your pump,right side,driving direction,lock and unlock your car,observe your pump is working,if not,check or replaces your switch door actuator,ty
May 17, 2009 | 1984 Mercedes-Benz 190
Zj1217 door not opening
you need to clean your pump there is a safety feature in the washer that will not allow it to open if there is water in the machine if you open the pump be sure to have plenty of towels
Dec 26, 2008 | Zanussi ZJ1217 Front Load Washer
When door opens dishwaher does not switch off.
Hi siphoxolo,
I'm Harvey the Master Plumber.
Your problem is: Normaly when you open the door the machine should switch off - the pump constantly pumps. You have checked the water inlet etc no problems there.
Sounds like a bad door switch. It's in the top of the door panel. You have to take the door apart to replace it. Not a job for the average homeowner. You might consider the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 06, 2008 | Bosch 24 in. SGS65L02 Logixx Built-in...
Bosch Nexxt 300 Series WFMC2201UC Logo
552 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
