Question about Kenwood KDC-MP228 CD Player
Kenwood kdc mp228 now working with amp/subs
My kenwood kdc mp228is hooked up to a Rockford 600watt amp and a single 12" alpine sub. all connections are correct, and my sub is not blown, but he amp isn't working, and the sub isn't getting a signal. is my sub too powerful? I've heard of a guy who has a 600watt amp with his mp228... please advise, thank you
  • belovarski77 May 05, 2010
    ALL connections are right. I took it to a shop and even got a new RCA cable. they said that its the head unit but couldnt find the "SW (subwoofer) ON" option. SO where is that???
    Champion:
  • 208 Answers
Hi, ensure amp has 12v on the "+" and "rem" terminals and has a good ground to the amp, This is all the amps needs to start up
Posted on May 05, 2010
  • Chris Jowsey May 14, 2010
    the user manual states that this model only has 2 channel line out (rear channel L & R). this is affected by the fader control so ensure that the fader control is set to the centre or rear positions - if it is only set to the front, then you will have no sound - there is no subwoofer function on this unit.
    P.S you never did say whether your amp was starting up. most amps have a status light on them indication whether it is "on" or in "protection" mode
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
I agree, as long both terminals are getting power and a good ground it should kick on, if it don't it might be shot..
Posted on May 13, 2010
Subs make one very loud bang when car starts i have a kenwood kdc 528 deck and 2 pioneer 12in subs an amp
Hook it up properly to the deck remote on wire ,(Dude) End stay off the (Drugs)
Nov 22, 2012 | Pioneer Car Audio & Video
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Sub will drain all the sound off the front speakers
if you have both amps connected to the same power wire this will happen...run another power wire to the alpine and this should solve the problem.
Jul 25, 2009 | Rockford Fosgate Punch 301S Car Audio...
No sound from my front and back speakers in my van ive got subs
Make sure that when you hooked up your 4 channel amp to the remote turn on lead it is the same as the sub. Only hook amps to the Blue w/ white strip. The solid blue is power antenna lead and will lose power when on CD, ipod etc and only stays powered when the Tuner is on. Hope this fixes your problem.
Jun 03, 2009 | Kenwood KDC-MP428 CD Player
I was given a kenwood kac742, what do i have to do to hook up 2 subs to it tom
You need:
1) 2 4-ohm subs
2) Appropriate enclosure
3) Amp wiring kit with RCA's
Connect each sub to a separate channel and set both mode switches to "MONO" (center position). In 2-channel mode, this amp is only rated at 80 Watts RMS, so you need relatively small and efficient subs. I'd say nothing bigger than 8" or perhaps 10". Rockford-Fosgate P1S48 (8") and R1S410 (10") will work OK with 50-150 watts RMS. Some others will also.
Mar 25, 2009 | Kenwood Car Audio & Video
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Wiring
The two seperate wire terminals on the sub are for dual voice coils which means. If You hook up the first terminal to the second terminal then run speaker wire from the second terminal to the amp.It should then increase the subs frequency response and sound better which also means it will be able to handle more bass. As to just having one voice coil hooked up. The two terminals is pretty much the bridge for the sub.
Dec 21, 2007 | Car Audio & Video
Kenwood KDC-MP228 CD Player Logo
206 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
