Question about Daewoo KOC-925T Microwave Oven
What is the best way to cook popcorn in this oven?
I tried to cook microwave popcorn, but the corn do not explode well in the specified time (3 minutes).
  • Rich May 11, 2010
    Hi . are you using a pre packaged , microwaveable pop corn? or some other product? How old is the corn? -
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
Years ago, my dad decided he'd try putting the popcorn in a bowl of water for 30-60 minutes before popping. The results of his experiment were amazing! The added moisture in each kernel probably added at least 25% to the volume of the finished product. If you have the time, I'd recommend trying this.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on May 18, 2016
  • Daewoo Master
  • 9,098 Answers
It's best to put the popcorn bag on an upside-down paper plate, and be sure it's off-center, not in the center of the turntable.
Raising the plate and keeping it slightly off center allows more even heating and also protects the glass tray from overheating repeatedly in the center, which can eventually lead to its cracking.
If it still won't cook properly, the magnetron, cooling air flow or power line voltage may be less than it should be.
Posted on May 06, 2010
How to cook corn in microwave
Depends on your microwave and the popcorn. Your owner's manual will have instructions. The first couple times, it will probably be by trial and error.
BTW--the best way to get rid of stinky burned popcorn smell from a microwave is to microwave a small amount (1/4 cup) vinegar until boiling and let it set in the microwave for a while.
Apr 24, 2016 | In Microwave Ovens
How to pop popcorn
place a teaspoon of cooking oil in the pot and place on stove. Put a small amount of corn to be popped in the pot and the heat will do the rest. 1/4 cup of corn will probably overflow the pot so use small amounts first until you get the idea.
Feb 05, 2015 | Panasonic Inverter Countertop Microwave
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
Shut's off after cooking popcorn, only popcorn, won't restart for 15 too30min.
Sounds like the magnetron is over heating. Try putting a 4 0z cup of water in the oven along side the popcorn bag. See if this helps. Usually, the oven only runs 2 to 2.5 minutes for a bag of popcorn. You may have to experiment with the slightly different cooking time...
Oct 29, 2013 | Magic Chef CMV1000B Microwave Oven
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Magic Chef MCD1611W
What should my powerlevel be on on my microwave because it keeps burning my popcorn
Your power level should be on high, but you shouldn't rely on the oven to time the cooking. I have yet to find an oven that won't burn popcorn if it has a preset POPCORN button. Press it and walk away and next thing you know, you've got charcoal. You should always stick around while making popcorn. Stop the oven and take the bag out when the time between pops drops to 1 or 2 seconds. The corn will continue to pop on its own for a bit because of stored heat, but you won't burn it. You'll never get 100% of the corn to pop, so don't worry about unpopped kernels.
Feb 28, 2011 | Emerson MW8777W Microwave Oven
Overheats and shuts down in popcorn mode (2:50)
well fancy that???? popcorn has very little water in it to heat up,,,
have you looked at the cooling vents on the back of your microwave
if there blocked with dust or fluff thats your fult,, mind you if the microwave is trying to cook a dust bin full of popcorn all in one go
it will give up when it over heats after a fuw minuets,,, eat corn flakes insted???
Oct 21, 2009 | Danby Microwave Ovens
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
Oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
Jun 21, 2008 | Magic Chef MCD1311ST Microwave Oven
Daewoo KOC-925T Microwave Oven Logo
187 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
