Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV KV32FS16. TV turn on problem.
Sony TV KV32FS16. TV started to take more than one button press to start. This got and worse till I was pressing the start button more than 20 times to get it to turn on. This kept increasing until it would not turn on at all. Self diagnosing feature LED was flashing 4 times. Manual says this indicates I-prot, lack of vertical pulse or IC 502 failure. What the heck is I-Prot?
The progressive nature of the failure indicated a leaky capacitor to me. Any thoughts?
  • jimca39 May 05, 2010
    What does I-Prot mean.
    Which capacitors are the most likely to fail in the power supply.
    My TV is KV-32FS16
    +13V and -13V are not present at IC 502
  • Sony Master
  • 11,800 Answers
All will fail in time, the secondary filtration ones first. The fact that +/- 13 volts is missing is the indication to start with it first. After that check all voltages and finally the power transistor itself. If in doubt change all capacitors before doing anything else, they are cheap enough to start with that.
Posted on May 05, 2010
  • 2,335 Answers
Hello.
As I understand it, this is an "i-prot" code which implicates voltage suplpy to the A-board. The probable cause locations listed are as follows:
1. +13V is not supplied (A board)
2. IC561 is faulty (A board)
If you are eager to chase down the voltage supply problem yourself, may I recommend this Agoraquest thread as a good place to start, where your model and your symptoms are discussed?
I hope that helps.
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Need codes for programing a hitachi tv
The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
May 22, 2010 | One For All URC-3021 Remote Control
When i press the tv/sat button the display says unlock. How do you unlock it
Problem fixed,
I turned the unit off waited 10 seconds then turned it back on pressing the power button and set up button together this started demonstration mode.Let the demostration mode run till finished then turn it off again wait 10 seconds and turn it back on.This solved the problem
Dec 23, 2009 | Sony STR-DE545 Receiver
RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
Jun 27, 2009 | GE JASRM24912 Remote Control
Code for my sony tv with rcr remote
to solve: manually turn on t.v., hold t.v. button then hold on/off while holding t.v. button till on/off light turns off. after 3 seconds on/off will turn back on. release both keys, light should stay on. press and release on/off key repeatedly, waiting 4 seconds between each key press, until ur tv turns off. after component turns off you have found the correct code. you have to save the code by pressing the stop key. should work after that, dont forget to press stop or u have to start over!!!
Sep 22, 2008 | Televison & Video
Sony Trinitron KV32FS16==> Need to push pwr button multiple times
after it fails how many times does the red LED blink? check the board very closely for any cracked solder. and then check the main regulators. also look to see if you have any physically bad capacitors, they might look like they are exploding on the top.
Feb 03, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Cant control toshiba tv model ce19t11
it is one of these code you will have to try them all till you get the right one they are 059    060    019    014    052    075
1 turn on tv to be prog
2 on remote hold down set
3 whilst holding set button press and release power button
4 release set button
5 press tv button on controll
6 using key pad key in code
7 press enter button
8point remote at telly
9 press power button c if it works
if not work start again but use next code keep going till you get it to work try this site as well http;//esupport.sony.com
Oct 26, 2007 | Sony RM-V302 Remote Control
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
