Question about KitchenAid KSSC42QM Side by Side Refrigerator
KitchenAid KSSC42QMS01 The condenser fan is not working. Is it safe to let the refrigerator run until the repairman can get to it or should I shut it off until it's fixed? I obviously don't want to cause any additional damage. Is the fan something an average handyman can fix?
  • Mike Smith
    Mike Smith May 12, 2010
    You can have a regular small fan blowing on the compressor until the refrig fan motor is replaced . You should easily be able to replace . Only 3 screws hold the motor on .
  • mg12480 May 13, 2010
    It turned out to be the control board and not the fan.
  • KitchenAid Master
  • 4,654 Answers
No it is not safe it can damage the compressor internal overload. Fans must work when compressor is on. Thanks, Sea Breeze
Posted on May 12, 2010
  • 3 more comments
  • John Tripp
    John Tripp May 12, 2010
    I left out part of your answer and yes it is something you could do if you know or have someone to help get me voltage readings, if you would like my assistance just tell me here. Sea Breeze
    Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
    Thanks, Sea Breeze
  • John Tripp
    Yes you can place a fan there and replace the fan motor if the fan is part defective. I would also want to make sure that you get 120 volts at test point P6 #1 to neutral coming from motherboard to insure the fan is the problem. I also have found that some models have a cycle relay place on condenser to turn the fan on and off as needed. Click here=> KSSC42QMS01 Wiring Diagram, I will try to locate a fan motor part number ASAP, Thanks, Sea Breeze
  • John Tripp
    Click Here for Condenser Fan Motor Assembly=> 2206036 or 1378525 Fan Motor top of page. If you need further assistance please let me know, Sea Breeze
  • John Tripp
    All Technical Sheets for your model can be found Here=> Model Number KSSC42QMS01 near bottom and each sheet tells a little more about service and test along with diagnostic of your model. I hope that aasc and I have helped you and feel free to as each of us for answers, and Thanks for using Fixya, Sea Breeze
  • John Tripp
    John Tripp May 13, 2010
    Sorry it was the control board.I did want you to check the power coming to the fan and not just change out the fan. I realize for some people that these things to do are best left for a qualified technician. At Fixya we have a lot of DIY, Do it Yourselfers that want to do it with assistance. A fan also will not always just stop when going bad. They also can damage the same part of the motherboard if not tested per Whirlpool's Authorize Technicians. Whirlpool now owns KitchenAid , Maytag, Samsung, Jenn-Air, Amana and the list goes on. Let us know if you have any other help request and just maybe it will be something easy, Thanks, also for telling us what the problem was. This helps many others as they read your post. Thanks, Sea Breeze
Kitchenaid superba condenser fan not working
Yes, the main board is located in a metal box mounted on the side-wall next to the compressor. Send it in to corecentric or fixyourboard for a re-build. The new board is pricey, and often not available, but the refurbishers have a better warranty than the manufacturer- if your fan is new and has no voltage, the main board is suspect.
Apr 25, 2016 | KitchenAid Refrigerators
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
My fridge won t work no more ... both sides are warm
The most common problem is the condensing coil is probably loaded with lint and debris. In behind most refrigerator is a fan and it blows on condensing coils. If the condenser is dirty and blocks air flow, the cooling system can not shed the heat. These coils should be checked at least every year, more often if you have pets that shed a lot.
Hope this helps.
Nov 02, 2014 | KitchenAid Superba Architect KSCS25INSS...
Why Refrigerator does not cool?
condenser fan must run if it is to cool. does compressor run but not fan. fan need to be replaced ... will not cool until it is fixed.
Aug 26, 2014 | KitchenAid Refrigerators
Kssc42qms01 side-by-side. About a month ago refridgerator side was too warm. Removed top grill and cleaned coils. All was fine until today. High temp warning (beep) and both compartments now reading...
I just checked my sheets on this unit, this unit has to be turn off first, turn it back on and can only enter the service mode within 13 second after power up. Hold the filter rest then power button for three second. I hope this helps. Good Luck
Oct 01, 2013 | KitchenAid Refrigerators
Holiday mode refrigerator
If it is on Holiday Mode, press the key just once more. Page 8.
KitchenAid KSSC42QMS01 Use Care Manual
Jul 24, 2013 | KitchenAid KSSP48QMS Side by Side...
Condenser fan not working
if evaporator fan inside refrigerator is running check for blockage at condenser fan, if no blockage condenser fan is the problem
Aug 24, 2012 | KitchenAid Superba Architect KSCS25INSS...
Our freezer and reridgerator temps are climbing and the front of the middle divider between the freezer and fridg is burning hot. What's the problem?
There is a condenser fan down at the compressor area that isn't running at enough rpms to properly cool compressor. You will need to clean the condenser coils and also install new condenser fan. The compressor is over heating and shutting down on internal overload. Replace this fan and you will be good to go. As an emergency aid you can pull unit from wall about 6 to 12 inches and place a fan in the front area out of your way letting it blow air thru the front over the compressor until you can get the fan. Hope this helps and good luck.
Feb 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid KSSC42QMS01 refer is beeping. display is also flashing. cools normally.cannot enter diagnostic mode. Have not seen condenser fan spin, even while compressor is running. no voltage at fan
three things to check out.
1)the fan wiring's are they getting cut in between or burnt or short.
2)if the wires are proper ,then its faulty fan motor the Fan needs replacement.
3) if the compressor relay is faulty then also fan will not work.the relay is located beside the fan and compressor.
if not familiar with checking a local repair technician familiar with your brand /model is advisable.
to get required parts you can get it from
www.repairclinic.com
or from www.partselect.com
its a common problem occurs many times and checking /replacing the listed parts solves the problem.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | KitchenAid Refrigerators
Stopped cooling and freezing
check that the condenser fan is working and condenser is clean.. check that the evaporator fan is working may have to push switch in to make it run. if ice is visible behind rear freezerwall you do have a defrost problem find defrost timer and with a flat head screwdriver turn it until you hear a click and everthing shuts down. if yoou hear ice cracking you have a bad defrost timer(very common failure)you may have problem in the defrost heater but you might find that a little over your head and a repairman might be the cheapest way to go, because buying parts can be expensive and they are not returnable
Jan 19, 2009 | Kenmore 53642 / 53644 Side by Side...
KitchenAid KSSC42QM Side by Side Refrigerator Logo
768 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
