Question about Sony Little Big Planet
How to play transformers 2 - Sony Little Big Planet
  • 50 Answers
Put it in the cosole and press play
Posted on May 05, 2010
Model el 174 4. Where can I get a replacement transformer?
you can buy at your local electronics/electrical store by the way what is the current in your country? if 220 volts just by a step down transformer to be able to work your 110 v fan...if 110 volts already why you need to put transformer if only plug and play...
Sep 21, 2015 | Dryers
I am playing my game console with a transformer and then suddenly the transformer died.. I checked it out and its very hot... I haven't open my game console since then... My question is... Will my game...
If your transformer failed, chances are that your console will still work. Try to borrow a similar transformer to test it out. If the console was damaged, you will not be out the cost of a new transformer.
Feb 06, 2015 | Video Game Consoles & Games
How do i get my google play apps from my galaxy S5 to my tablet
You should be able to sync them. Also if you have Google + you should be able to download the apps on your tablet and sign on to them that way; this depends if you use Google + on your Galaxy with the apps. Google play may also be able to help with this.
Aug 07, 2014 | ASUS Transformer Book T100
CAN I PLAY THIS SPEAKER WITH 12V BATTERY. I USE
Hi
sure you can
the time that you can play is deppends the charge in the battery
any convertor you get must have output 12v
Jan 04, 2011 | Sony SRSD25W WHITE SPEAKERS 2 Speakers
RCA Model STAV-3870 Receiver
Very likely that the internal thermal fuse opened on the main power transformer. With the power cord unplugged, Check the resistance on the ac input of the transformer should read less than 10 ohms. Contact me when you know. I might be able to find one.
Jan 19, 2009 | RCA Audio Players & Recorders
Blown transformer
I also have the GPX under-counter TV, same problem. I believe the transformer is AC-AC, because both wires out are red... I actually have two of these units, one doesn't work at all, the other has enough power to play the radio, but not the TV. I swapped the transformer from 1 into the one that was completely dead thinking #1 had a bad tuner, but the same symptoms exist now in #2, making me think that one transformer is completely gone and the other is malfunctioning. I'll try the VX 79NP on both and try to remember to post the results back here....
Jan 16, 2009 | Curtis KCR2610 7 in. Portable Television
US portastudio 2488: Can it play when connected with a transformer
The 2488mkII manual specifies that the unit can operate with either 120VAC, 60Hz (USA/Canada), 230VAC, 50Hz (U.K./Europe), 240VAC, 50Hz (Australia) so you should be fine with a transformer which can accomodate 230VAC, 50Hz).
I have actually conversed with people who have been using the 2488 in France without any power problems.
Cheers,
bd.
Sep 12, 2008 | Tascam 2488 Portastudio Multitrack...
Some gmes won't play.
Ok. Do you have a NTSC system?
Some PAL games will only run on standard and some will only run in HD and some will run on both if the PS3 is NTSC. The PAL games output at (576i/p) while the NTSC outputs at (480i/p). So honestly, I think that is your problem. You have a NTSC system and PAL games. If you do not have a HDTV then you will need to exchange those games for the NTSC version. Sorry for the bad news. It's not Sony's fault, it's how the game developers coded the games.
I hope this helps. Good luck to you.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
AVR 1803
There is a thermal non resetable fuse built into transformers primary. There are two leads from a connector that go to Primary of transformer they may be yellow and white leads. If there is no continuity between these two wires Transformer is defective. With Power unplugged pull connector and measure with ohmmeter. Fuse is buried pretty deep inside transformer and some technicians can get it out and replace it but it is not easy.
Jan 17, 2008 | Denon AVR-1803 Receiver
Sony Little Big Planet Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
