Question about Linksys Wireless-G WRT54G Router
Can not connect a Mac laptop wireless, why ? Got connection for a few seconds and than loose it: "connection time out" and also does not accept the password. Very weird. Any idea what's the cause ? Have also done the settings wizard a few times, everything seems to be OK from the router side, except connecting the laptop. Please advise any other tips that may help. Thanks.
  • 71 Answers
What is your wireless security type on the router?
Posted on Jun 14, 2010
LENOVO G780 WiFi problems
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 02, 2013 | Lenovo G780 2182 laptop
Have Eee pc with windows7. wifi connection looses connection every few minutes.Network adaptor problem
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Sep 11, 2012 | ASUS Eee PC 900HA Notebook
My computer looses conectivity
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Jul 11, 2012 | Compaq Presario R3210us Notebook
Setup 64bit pass phrase on Belkin router. All wireless devices say,
Do your other devices support 64bit wep, and are you selecting that as your encryption type on each device. For example I know on my cellphone I have to specify the type of encryption that is used. You might also log into the router, just to double check the encryption type and the pass phrase (even if you are spelling it right).
Jan 31, 2012 | Belkin Computers & Internet
My laptop wont stay connected to the internet
Jan 27, 2012 | HP Compaq nc4200 Notebook
2170W wireless connection to mac computers
My suggestion would be to connect an ethernet cable from the printer to the router. This is a more stable connection for the printer on the network.
All of your wireless computers will be able to connect to it and print to it as long as they are connected to the network.
To get the printer back in wired mode, you will need to reset the printer and network card of the printer.
1. Turn off power
2. Hold down go Button while switching back on
3. Wait 2 secondes before letting go and press the go button 8 times quickly
4. Wait for the unit to finish warming up
5. Repeat steps 1 and 2
6. Wait 2 secondes before letting go and press the go button 7 times quickly this time
7. Wait for the unit to finish warming up then plug in the ethernet cable.
Mar 28, 2010 | Brother HL-2170W Laser Printer
My older G4 white 12"macbook laptop drops the wireless connection
try to update the Mac Os x and also the airport card drive.This can solve the issue
Feb 20, 2010 | Apple MacBook Mac Notebook
ACER 5720 WIRELESS CONNECTION PROBLEMS
Are you using security?
If you are try changing between wep, and wpa
If that still does not work use mac filtering
May 27, 2009 | Acer Aspire 5100 Notebook
Can't find mac address on my acer to connect to wireless network at work
i think the wireless at your work filter computers based on their MAC address as a security measure hence you are unable to connect..
to find your comp's MAC address follow this:
  • From the Start button select Run
  • In the box which appears type cmd and click OK
  • A new windows will appear - at the prompt type ipconfig /all
  • The MAC address will be referred to as the Physical Address and is made up of 12 characters e.g. 00-D1-AB-F2-G3-89
    You will have a separate MAC address for your wireless card and your Ethernet card. Make sure you use the correct one
  • do ask the admin of your work wireless system to add your comp's MAC address so that you are able to connect..
    am no expert but love to help out...hope it helps you...all the best!
    Oct 27, 2008 | Acer Aspire 5315 Notebook
    Losing internet connection when I try to connect laptop to wireless router
    Your cloning the mac address - thats the problem. It should use it's own mac address to connect to the modem. You need to power down the modem, then repower after a minute or so to let it connect to the new mac address. The problem you are seeing is due to network collisions betweenj the desktop and the router with the modem.
    Nov 29, 2007 | Belkin (F5D7230-4) Router (587009)
    Linksys Wireless-G WRT54G Router Logo
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
