Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Corrupted Audio Card
How can we reinstall it? Is there an available installer that can be downloaded online?
  • Anonymous Apr 10, 2009
    hi i have realtek audio driver sofware but its not working so i want to install it now what must i do
    Scholar:
  • 124 Answers
Was it corrupted by a power surge? Did you plug the speakers into the audio card jack while they were on and you heard a crackle or pop? If so, power off the machine, unplug it, touch a nearby metal object to ground yourself, open the case, disconnect any wires to the card, remove it from the motherboard and then put it back in. Reverse the steps and then power it back on. It should work.
If it still doesn't....
Go to the manufacturers website and find the support page. Download any necessary drivers for your audio card. Open them and they'll auto-install (usually). If it still doesn't work then try your card on another machine somewhere else to verify if it's fried or not.
Good luck!!
Posted on Mar 26, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Heres the quick solution...
http://www.bram.us/2008/08/20/fix-to-the-hd-audio-bus-driver-failed-to-load-0xe0000227-realtek-high-definition-audio-driver-install-has-failed-errors/
Posted on Sep 06, 2008
SOURCE:
When I try to install drivers windows 10 tells me it is not compatible and will not let me proceed
Hi, you will have to go to the makers of the graphic card online and see if its possible to download straight from their site windows 10 drivers for your card. It should tell you on the graphic card site if they are available for windows 10.
Mar 06, 2016 | Aluratek Auh200f Graphic Card - Usb. Usb...
Volume permanently got decreased in dell
Sounds like your driver might be corrupted or has issues. Try downloading and reinstalling the Audio driver.
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.
Jun 05, 2012 | Dell Inspiron 15R Notebook
Asus x50SLseries my audio jack not working:
Maybe you corrupted the audio driver. Download and reinstall it.
Get onlineand got to www.google.com In the google search box type: "ASUSSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.
May 07, 2012 | ASUS Computers & Internet
I have problem with sound of my p.c. please solve my problem
Hi.
Most of the problems with Audio are fixed reinstalling factory device driver for the audio adapter. Go to Acer support website, download and reinstall the audio drivers for your PC:Service & Support,
If that does not work then the problem may be hardware. In that case you will need a replacement audio adapter. If the computer is a PC you can install an internal card. Here a cheap one:StarTech.com 5 Channel.
If the problem is hardware and you do not want to disassemble the computer you can buy an external audio adapter. Here a USB adapter available for few dollars that will do the job: Converter Sound card.
Regards.
Ginko
Aug 08, 2011 | Acer Audio Driver Realtek.exe
What do i download to get my sound back
If the audio driver is lost or corrupted then re-install the audio driver.
You can download the audio driver from the manufacturer's WEB site. Open up your computer and have a look at the audio card in the expansion slot, note the make and model of the sound card and then go to the manufacturer's download.support WEB site, select your model sound card and then download and install.
If the sound card is built-in on the motherboard then note the make and model of the motherboard and go to the manufacturer's download.support WEB site, select your model motherboard and then download the audio driver and install.
Oct 23, 2010 | Computers & Internet
LEXMARK PRINTER X4650 OCR folder not found
The scan software(OCR) may not be installed in the computer or probably got corrupted. Reinstall the software. The Lexmark scan software(OCR) can only be installed using the installation cd that came with the printer. It's not available online for download since it's a big file. If you don't have it or you lost it, I suggest you contact Lexmark Technical Support for assistance.
May 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
Missing all in one program
The All-in-One software might be corrupted or not installed properly. Try to reinstall it. The software can only be installed using the installation cd. The Lexmark All-in-One software is not available for download online since it's a big file. If you don't have the cd or you lost it, I suggest you contact Lexmark Technical Support. They can send you one for free.
May 02, 2010 | Lexmark X2250 All-In-One InkJet Printer
Audio not working on advent 4211c netbook. Driver shows 'unknown device on high def audio bus'
The audio driver needs to be reinstalled. If you have the disc that came with the computer, it will be on there. If not, you can go to Advents website, go to support, and download the latest audio driver for your computer. Going to their website is probably faster and easier than trying to locate the correct driver on the disc. Hope this helps...
Feb 02, 2010 | Advent 4211c Notebook
I have a dell dimension 8250. I lost my sound, but
Either your soundcard driver has gotten corrupted or your soundcard has died. You can find both the driver & info on what card you have at www.dell.com. Click on the support link and you can either input your Dell Service Tag & get exact system info, or you can look it up using the system model #. The driver will be available for download. Try reinstalling an updated driver first. If that still doesn't work check your device manager to see if a soundcard is listed. If it is not then more than likely your card has died and will need to be replaced. Hope this helps.
Jul 11, 2009 | Dell Dimension 8250 PC Desktop
Audio installing
THE PROBLEM IS THE AUDIO DRIVER OF INTEL D845GLLY MOTHERBOARD FOR XP SERVICE PACK 2 NOT SUPPORTED PLEASE HELP ME FOR DOWNLOAD THIS DRIVER NOW
Oct 21, 2008 | Intel D845GLLY Motherboard
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
214 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
