Question about Craftsman C3 19.2 volt Combo Kit, Drill/Driver & Impact Driver
How do you repair 19.2 volt c3 li-ion batteries?
  • 382 Answers
Typically they are not worth repair. The cells are expensive.
Time to buy a new set, since when the batteries go the tools are worthless.
Posted on May 05, 2010
  • HOP1124 Oct 01, 2010
    Come on. Don't play us. Give us the parts list that is with cell. Please
DC B101 charger. Why doesn't it charge?
May be It can mean your LI ION battery is out of range by the deep discharged protection. !!! your charger is not defect and your battery also not in 80% of this cases you are certainly not the only one with this problem . i think your battery was or is new or for a long time not used have i right ? or it was long lay down in the stockroom by the store before it was selling as i know from experience it by the brand Hitachi its fast much allways going that way. in priority the little 10 volt batteries made of li-ion can have on stock for 5 years its out of range , but i send it back and for service they come back full loaded again and full of capacity. its fully under service and they know that problem, there are no costs as all people with Li Ion tools to sell should know this or asked by purchase by some companies to load it full before buying a new tool with li-ion batteries because it prevents a disappointment and a drive to the shop again.
Note to control it that way 80 % in case of this the charger is not defect ask someone or your dealer or friends to test that charger with a new or other functional or regular used Dewalt fitting li ion battery , then you know for shure that its realy not defect, but your battery can be boosted with a special cadex charger if its was little used but i have made in experienced an discovery (but only on Dewalt li ion batteries..because there are only 3 poles on Dewalt accu s to find its missing that special grooved protection circuits with multiple contacts inside on the li ion batteries as to find by all other regulary brands too find) used a simply auto charger 12 volts 4 amp placed + and - corresponding the pins + and - and for 20 seconds because its li-ion (always by unknown experiments wear safety glasses) under the load and repeat that 3 times on a 14,4 volt li ion battery and after i switched that battery fast after that short boost again in the original loader and if the lamp on the charger was again been continues red thats mean it was reborn new and accept its loading again in the official dewalt loader and it was be accepted from that time again without repeating the same problem after fully loading it again. its made me happy but only by Dewalt was this experiment functional simply + on + and - on -
Beware do not this on other brands like Panasonic Makita Hitachi or other Brands milwaukee to do this li ion action because its has no cure wasting not your time and do not experiment full on the separate cells it can made great explosions without electronic technical impossible because of complex protections that are marketing technical made ONLY by special CADEX chargers are used for it to boost it so it will be again fully functional again .
Li ION is not comparable with Nickel Cadmium or nickel metal hydride, the first must be trained for capacity and the second not but do not load nickel metal hydride batteries in the freezing cold most outside or in cellars the lasting life of that batteries is very short after that . the capaciti will loose and is not coming back and is very bad to boost., Nickel Cadmium is heavy and great instead of Nickel MH . and material is expensiver the only good improvement of NI MH is the weight and the building material, and no capacity memory if its used under normal temperatures. above 0 degrees .
Li-ION hold them as much on the charger change both fast after use will long last the life of the battery.
Oct 13, 2015 | Dewalt Drills
WHAT IS THE VOLTAGE (SAMSUNG S3310 MOTHER BOARD SMALL BATTERY)
It's a 460mah LI ION battery 19 Volt (roughly), replacements can be purchased at most cell phone shops and online at amazon, ebay, etc.
Nov 16, 2014 | Samsung Cell Phones
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Aug 23, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery specs for IBM T43
Voltage: 10.8 Volts
Capacity: 4400 mAh
Battery Type: Li-ion 6 Cells
Voltage: 10.8 Volts
Capacity: 6600 mAh
Battery Type: Li-ion 9 Cells
Sep 27, 2011 | IBM ThinkPad T40 2373 Notebook
My Makita BHP451 Li ion battery drill periodically the varible speed does not work, ie. the button works as a on/off switch - any idea what's wrong. Thanks Bjarne
Bjarne, odds are the variable speed function of the trigger is failing. There are Makita repair centers that perform repair, and sell parts if you want to take it on as a DIY project. Before proceeding, I would make sure the warranty has expired. If it is still in warranty a Makita repair center should repair it for no charge.
Dec 19, 2010 | Makita LXT202 BHP451 18 Volt Hammer Drill...
My Kodak Easyshare Z1275 has short battery life. sometimes even newly charged 2600 MaH batteries cause problems. Powers up, lens extends, opens screen to set time and date then powers down. Sometimes i can...
wait, do you have Li Ion batteries or Ni MH?
I think that Kodak recommends Li Ion batteries which have a higher voltage on them.
I got some generic Li ion battery packs off of Amazon.com, with better specs. than Kodak, and they work fine for my Easyshare z1485 IS camera.
It cost me like $80 to get the charger and two battery packs that are Li Ion, but it's worth it.
My battery packs are rated at 2000 mAh 3.7 Volts each. It's the voltage that counts. You see, if you would split that in half, the voltage for each AA battery is 1.85V which is much higher than the 1.5V that regular Alkaline or Ni MH batteries are rated at.
I tried Alkalines, and Ni MH to no avail. But, the Li Ion batteries, did the trick for me.
Good luck on this 'repair' or battery upgrade.
Jul 23, 2010 | Kodak Cameras
Do imported hxp battrys damage new zealand sold tools cheers
Well, it's highly unlikely as long as it is a HXP 18V Li-ion battery because pretty much all hitachi stuff is imported. The companies HQ is in Japan and so id the largest manufacturing plant. I hope this helps please rate this thank you
Mar 17, 2010 | Hitachi Hxp 18 Volt Li-ion Hammer...
Battery don´t work
try to replace new battery charger.
Feb 22, 2008 | Astar Trent PD-3070
Craftsman C3 19.2 volt Combo Kit, Drill/Driver & Impact Driver Logo
390 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
