Question about Aiptek HyperPen 12000U (HYPERPEN12000U) Graphic Tablet
Help? This is a loop! - Aiptek HyperPen 12000U (HYPERPEN12000U) Graphic Tablet
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details and the complete make and model number of the product.
Thanks for using FixYa.
Posted on May 12, 2010
CAN YOU USE ANY BLANK DVD TO MAKE LOOPED VIDEOS BY JUST CHANGING THE SETTINGS?
Hi Leah
There are two options that might work for you. The commercial DVDs you buy that loop, have a setting enabled when they are created that causes the player to loop. A lot of the programs that you use to make dvds at home have the ability to enable this setting as well. It depends on what program you use so check the help files or do a search for Make Loop DVD With ( Your Software ). Some players also have a playback option called looping, continuous play, or even store demo mode that would allow you to run any DVD in a loop mode.
Mar 23, 2014 | ASUS P5GZ-MX Motherboard
Gigabyte z68x u5d b3 in constant 10 sec. boot loop
Buy A New PC!
This One Is Eather Defective Or Dammaged Beyond Repair And Needs To Be
Replaced!
Mar 01, 2013 | Computers & Internet
Details I record drum/ bass and synth loops into logic and then send them to the rc50 loop pedal, i had 50 seconds of recording time left so i added a new track which left me 25 seconds of recording t
Likely the memory is fragmented into tiny snipets much like hard drives get. For looping, the memory likely has to be contiguous chunks. Clear the memory and load each in sequence.
Feb 23, 2013 | Audio Players & Recorders
My pioneer cdj 800 mk2 is constantly looping itself, please help!
This probably means that one or two of the tact switches which enable the loop (loop in, loop out, reloop) is damaged and need to be replaced. In pioneer cd players when a tact switch is semi-broken, then if you press another button then it looks like you pressed that semi-damaged switch. For example you may hit "cue" and the cdj loops! It is quite common.
If you have some soldering skills this is the tact switch:
http://artaudioparts.com/product/dsg1079/
Nov 04, 2012 | Pioneer CDJ-800 Turntable
Simplicity SW432 Loops big but even
check the tension settings
change the needles
if these suggestions don't help, then it's possible that the machine is out
of time & needs to be serviced at a sewing machine shop
Apr 25, 2012 | Simplicity Serge Pro SW432 Mechanical...
My DL4 doesn't sound as it should in my series fx loop. Is there any way possible to solve this problem WITH OUT putting it directly into the amps input? I need help!!! I play my amp wich is class A...
your parallel loop only has input, a series has out and in, you need to patch the out of amp to the in of the pedal, and out of the pedal to the in of the amp fx loop. then you need to make sure your loop is turned on, via switch or footpedal.
Jul 05, 2011 | Line 6 DL4 Delay Modeler Effects Guitar
Front-Loading Automatic Washer is leaking water
if you have a wire loop in your hands
its more than likely the outside loop, the inside would still be looped on the boot between the door and tub
any way, if it is the outside lock loop it should have a spring connecting both ends
this loop goes around the door seal kinda behind a lip, if you inspect where the boot lips the panal youll see what i mean
the best way to put it back on
catch the top of the loop an the lip of the boot
keeping the rest of the loop as close to in postion as possible use two needle nose pliers to tretch the spring, you should be able to spread it far enough to slip the rest of the loop back into place
four hands are much better here I assure you
but it can be done alone, it just takes a lil paitence
and slow movements
hope this help
Oct 18, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Loop points are not accurate
you can not use a third party program to convert to mp, it won't loop right, use the windows media player to convert to mp
Sep 13, 2009 | Tascam MP-GT1 MP3 Player
PHP Troubleshooting
Most often the problem is caused by loops in your PHP. One common mistake is to forget to actually ++ add to the counter at the end of a loop, so your loop will continue to run forever. Another common mistake is that, you do add to the counter, but then accidently overwrite it again at the start of the next loop, so you never gain any ground.
Depending on what your loops is doing, this can cause your script to continue to output the same information over and over again (continuing to make the page longer and longer and longer) or it can keep processing the same information over and over without outputting anything giving it the appearance of a page that is trying to load but is lagging.
One way to help you spot this is to echo () the current counter number (or other useful information) at the beginning of each cycle. This way you might get a better idea of where the loop is tripping up.
If you're not using loops, you may want to double check that any HTML or JAVA you are using on your page isn't causing the problem, and that any included pages are without error.
Aug 05, 2008 | The PHP Group PHP
Aiptek HyperPen 12000U (HYPERPEN12000U) Graphic Tablet Logo
Top Aiptek Computers & Internet Experts
David
David
Willem.
Willem.
Gareth Cockram
Gareth Cockram
Are you an Aiptek Computer and Internet Expert? Answer questions, earn points and help others
